1. pnico's Avatar
    Hi
    I've had a few instances where my note 3 did a complete freeze and battery pull was Necessary. Is this typical from time to time?
    Thanks
    01-21-2014 09:49 AM
  2. VDub2174's Avatar
    I haven't noticed any lockups on mine yet. I haven't had mine long though.
    01-21-2014 09:53 AM
  3. yarnsrj's Avatar
    I only had that problem with a rogue app that wasn't completely closing and would cause my phone yo lock up. Uninstalled the app since I didn't want it and haven't had lock ups since. Check last 1 or 2 apps you recently installed.
    from my "Note 3" on Tapatalk
    01-21-2014 10:31 AM
  4. z06mike's Avatar
    I haven't had any lockups, but... EVERY phone will lock up from time to time. These are mini computers, and are doing a lot of, well, computing. Every so often, we throw a little more than they can handle at them or a rogue app causes some funky mess. As far as being expected, no way.
    01-21-2014 11:19 AM
  5. Kettle's Avatar
    I would also bet that it is a rouge app. I tend to install tons of apps that I only use one or twice and then never again because I lose interest or even just forget about them. As a result, I perform a factory reset every few months or so just to clear everything out and start anew. I then only install apps as I need them.
    I know some would view this as being a PITA but I like starting out with a new phone every few months. I will probably perform my next factory reset once KitKat is available.
    Sent from my SM-N900V using Tapatalk
    01-21-2014 12:01 PM
  6. z06mike's Avatar
    LOL, I've done the same with many apps at times. I think I had like 270 apps once, and in reality I would like maybe 100 of them .
    01-21-2014 12:41 PM
  7. runamuck0870's Avatar
    Put N3 in safe mode for 24 hours. If no lockups, likely bad app. If you get a lockup, hardware issue. If latter and you tell Verizon it locks up in safe mode, they will replace phone, SIM and/or battery until resolved.
    Or play sysadmin and try and locate offending app yourself.
    01-21-2014 11:20 PM
  1. Unable to Sign in to Gmail account
    By EpicInYourFace in forum Samsung Galaxy Note 3
    Last Post: 01-17-2015, 12:34 PM
  2. Should I upgrade to this?
    By Whatmanwhat in forum T-Mobile Samsung Exhibit 2 4G
    Last Post: 01-21-2014, 10:07 AM
  3. Issue w/screen flickering -related to low light sensor
    By agiudici in forum Sprint Samsung Galaxy S4
    Last Post: 01-21-2014, 08:17 AM
  4. Messaging App Always Scrolls to Top after entering new message.
    By alphacoleman@gmail.com in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-21-2014, 07:56 AM
