1. loverofhim's Avatar
    The volume on my Note 3 goes to maximum in the middle of a call. I lower the volume and within a few seconds it goes back to maximum. How do I keep this from happening? Thanks for any help!
    01-24-2014 12:05 AM
  2. Kelly Burby's Avatar
    I looks like your small up button is stuck into something which keeps it on pressing mode, i think you should clean up your phone because majorly it happens when phone gets dirty little cleaning up around the button using a small pin or wood toothpick would help you out !!
    01-24-2014 01:49 AM
  1. Email app does not sync updates or changes.
    By duo001 in forum Samsung Galaxy S4
    Last Post: 02-10-2014, 11:15 AM
  2. Replies: 2
    Last Post: 01-29-2014, 02:29 PM
  3. Hear ringtone when changing it?
    By PiggyMiddle in forum Moto G (2013)
    Last Post: 01-24-2014, 12:43 PM
  4. only call sounds only after 4.4 update
    By lithoman23 in forum Motorola Droid MAXX
    Last Post: 01-24-2014, 07:28 AM
  5. Volume Unresponsive (Cannot Change)
    By Dr3wX5 in forum Android 2.3 Gingerbread
    Last Post: 01-23-2014, 12:49 PM
