1. mort3770's Avatar
    Just got my Note 3 (SM-N900v) and first thing I tried to do is root it with Root De La Vega.
    True confession: I had no backup before trying to root.
    I downloaded the Samsung drivers and installed them.
    I downloaded the Odin3.09 program and installed it.
    Booted the phone into download mode.
    Connected the USB3 cable to the phone.
    Started Odin, added the root de la vega file and clicked start.
    It gets as far as this:
    <OSM> Enter CS for MD5..
    <OSM> Check MD5.. Do not unplug the cable..
    <OSM> Please wait..
    <OSM> Root_de_la_Vega.tar.md5 is valid.
    <OSM> Checking MD5 finished Sucessfully..
    <OSM> Leave CS..
    <ID:0/014> Odin v.3 engine (ID:14)..
    <ID:0/014> File analysis..
    <ID:0/014> SetupConnection..
    <ID:0/014> Initialzation..
    <ID:0/014> Get PIT for mapping..
    <ID:0/014> Firmware update start..
    <ID:0/014> SingleDownload.
    <ID:0/014> cache.img.ext4
    <ID:0/014> NAND Write Start!!
    <ID:0/014> FAIL! (Auth)
    <ID:0/014>
    <ID:0/014> Complete(Write) operation failed.
    <OSM> All threads completed. (succeed 0 / failed 1)
    After it failed the first time, I unplugged the phone and pulled the battery to start over, only this time when it powered up, it told me:
    "Firmware upgrade encountered an issue. Please use Software Repair Assistant & try again"
    I'm stumped and don't know what to do now. Any suggestions would be greatly appreciated.
    01-28-2014 04:34 PM
  2. Golfdriver97's Avatar
    See if Kies can recover it. Download from Samsung's site.
    UJ95x likes this.
    01-28-2014 04:37 PM
  3. VDub2174's Avatar
    You might wanna try this to root. It's supposed to not trip KNOX. It's what I used to root my Note 3.
    http://www.kingoapp.com/android-root.htm
    UJ95x and Dws51 like this.
    01-28-2014 04:41 PM
  4. mort3770's Avatar
    (In reply to VDub2174)
    I tried this program, but it too fails. I suspect because I'm not able to put the phone in USB Debugging mode?
    01-28-2014 04:55 PM
  5. VDub2174's Avatar
    Oh, that's easy.
    Settings > About Phone just keep tap on the build number (I believe). After about 7-8 times, back out and you'll see "Developer Options" right above About Phone. you can turn it on there.
    - - - Updated - - -
    UJ95x likes this.
    01-28-2014 05:00 PM
  6. mort3770's Avatar
    Oh, that's easy.
    - - - Updated - - -
    But I can't get into the phone at all. My two choices are to boot it into Download Mode, holding the 3 keys, or power it up and let it go right to the screen that tells me I need to use the "Software Repair Assistant". Maybe that's what I need, but I don't know where to get that software?
    I really feel stupid that I got myself into this mess. I even waited to make sure I had time to spend on setting the phone up right so I wouldn't have any issues. Ugh!
    01-28-2014 05:04 PM
  7. mort3770's Avatar
    Tried this program, failed to work. Maybe because of the mess the phone is in now?
    01-28-2014 05:08 PM
  8. VDub2174's Avatar
    That's right. I got excited, my bad......lol
    Let me look something up.
    01-28-2014 05:16 PM
  9. Golfdriver97's Avatar
    Possibly.
    Do you know what build number you had before you did this?
    01-28-2014 05:21 PM
  10. mort3770's Avatar
    Possibly.
    I looked at that before I did anything, but failed to write it down.
    01-28-2014 05:28 PM
  11. Golfdriver97's Avatar
    You can try reflashing the most updated version to your phone with Odin. However, I am not sure if that can be rooted.
    01-28-2014 05:38 PM
  12. mort3770's Avatar
    Even that would be a welcomed fix to the current problem. After all, I can't even use the phone as it is.
    01-28-2014 05:44 PM
  13. Golfdriver97's Avatar
    I owuld give that a try. At this point, you have nothing to lose and everything to gain.
    01-28-2014 05:53 PM
  14. UJ95x's Avatar
    If you weren't on 4.3, you should be able to flash the 4.2.2 firmware. You can probably find some on xda-developers.com
    All of the other reliable sources for those are a mess as of late
    01-28-2014 05:59 PM
  15. mort3770's Avatar
    I do know I am on 4.3, that's what the phone had when I checked it this morning. But I don't know what the build number is.
    01-28-2014 06:10 PM
  16. UJ95x's Avatar
    Wow. I'm an ***** lol
    All Note 3's are on 4.3, my bad
    01-28-2014 06:12 PM
  17. mort3770's Avatar
    I was finally able to restore my phone to new condition by using the Kies program and running the Emergency Firmware update/restore. I also had to run the program on another computer a second time. My computer runs XP and my daughter's laptop runs Win8. Not sure if it was the OS that mattered, or perhaps some firewalls, Antivirus or other things that interfered. In any event, my crisis is over. Phew!
    VDub2174 likes this.
    01-29-2014 11:49 PM
  18. VDub2174's Avatar
    Glad to hear everything's up and running
    01-30-2014 07:09 AM
  19. Golfdriver97's Avatar
    Glad to hear its fixed. Kies probably prefers Win7 at least.
    01-30-2014 10:09 AM
  20. Melqui Perez's Avatar
    Hi!!! Im having the exact same probleeeem please i need your hepl!!!!! Ive been trying to fix my phone with kies the wholeeee night and its not working!!!!
    04-26-2014 10:48 AM
  21. Melqui Perez's Avatar
    04-26-2014 10:49 AM
  1. S3 is stuck at Samsung logo
    By coveretess in forum Samsung Galaxy S3
    Last Post: 01-30-2014, 03:08 PM
  2. Stupid Kitkat changes help
    By DS1331 in forum Moto X (2013)
    Last Post: 01-30-2014, 07:11 AM
  3. Thinking about getting a Galaxy Gear... Need some feedback.
    By randomized in forum Samsung Galaxy Gear
    Last Post: 01-29-2014, 10:57 PM
  4. Major Problem - Please Help !
    By escorbar23 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-28-2014, 09:26 PM
  5. Galaxy Note 3 new user & Phonezoo
    By crozier7272 in forum AT&T Samsung Galaxy Note 3
    Last Post: 01-28-2014, 03:52 PM
