1. bontjes's Avatar
    My Samsung Galaxy Note 3 started rebooting randomly and quietly on Friday February 14 (or at least that was the first time I had noticed it) and I was wondering if it's just me or...
    I'm on Verizon and have no customizations other than the main applications that I've had all along and in my Galaxy S 3 before hand.
    Any thoughts?
    Sent from my SM-N900V using Tapatalk
    02-17-2014 07:14 AM
  2. Gekko's Avatar
    "main applications"? do you or do you not have any third party applications installed?
    02-17-2014 07:18 AM
  3. bontjes's Avatar
    I do have third party applications installed from the play store.
    My mistake. I'm so used to them that they have become my main applications!
    02-17-2014 07:25 AM
  4. Gekko's Avatar
    my guess is that you have a rogue or conflicting application installed. also it could be a bloatware app that migrated over from your S3 that is not compatible with your Note 3. i would delete all apps and reinstall only the ones you need one by one to find the culprit.
    The Case For Deleting All Your Apps
    good luck.
    02-17-2014 07:31 AM
  5. bontjes's Avatar
    good luck.
    Thanks man. I'll look into that.
    Have a great day!
    02-17-2014 07:38 AM
  6. dpham00's Avatar
    I have the same problem on both of my my Verizon Samsung Galaxy Note 3 's. I had the same apps installed on my s3 and Note II and never had the reboot problem. It is not too bad though, my HTC Thunderbolt would sometimes restart on its own several times a day.
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    02-17-2014 09:09 AM
  7. bontjes's Avatar
    I remember the HTC Thunderbolt would reboot all the time! Like every time I would go to do something! It killed my battery. I'm hoping that the Note 3 is better. I've had it for two months now and it just started last week. I was in the middle of a phone call when it happened on Saturday.
    Part of me thinks it's a carrier thing, but have no way of backing that up with evidence.
    What's really interesting, it's a silent reboot. No sound or anything. Whereas an intentional reboot it has sounds during the boot process.
    02-17-2014 09:39 AM
  8. dpham00's Avatar
    Yeah for me on my note 3 it is pretty infrequent. I set my boot to silent boot so I couldn't notice a difference.
    02-18-2014 09:31 AM
  9. bigwill0815's Avatar
    Mine does the same thing.... I'll be on the phone and then the call drops and the lock screen comes up like it's been not touched for 15 mins. I'm getting fed up with it. Either it's a signal issue which I never dropped a call on my iPhone in that spot, or it's something with the phone and this needs to be fixed
    02-20-2014 09:34 PM
  10. xceeder's Avatar
    Quick question does the note 3 have 4G lte??
    Sent from my Nexus 7 using Tapatalk
    02-20-2014 09:41 PM
  11. vlongxiav's Avatar
    Have a try recovering the factory setting .
    来自我的 MI 2A 上的 Tapatalk
    02-20-2014 09:47 PM
  12. dpham00's Avatar
    The Verizon Samsung Galaxy Note 3 supports 4GLTE on both bands 4 and 13
    02-20-2014 11:13 PM
  13. bigwill0815's Avatar
    No I have not tried restoring
    02-21-2014 06:17 PM
  14. bigwill0815's Avatar
    They are sending me a new phone
    02-22-2014 05:32 AM
  1. My phone is randomly sending old sms after restart.
    By pedrovas in forum Android 4.0 Ice Cream Sandwich
    Last Post: 10-31-2014, 12:01 PM
  2. Replies: 4
    Last Post: 05-20-2014, 02:36 PM
  3. how long can you use this thing without rebooting manually? or automatically?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-24-2014, 03:53 PM
  4. Way to reboot the N7 with screen taps?
    By J F4 in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-15-2014, 05:46 PM
  5. Reboot loop can't go into recovery
    By Apache Wang in forum HTC One M7
    Last Post: 02-15-2014, 05:12 AM
