Proximity sensor problem VZW
pmaisonet
71
So I'm assuming I'm not the only one having proximity issues with my Note 3. I love the phone otherwise. But doea anyone know how Verizon will fix or address this issue? This happen to anyone else? Thanks
Sent from my SM-N900V using AC Forums mobile app
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Verizon should replace the phone under warranty.
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
kboggs123
tap it on the table near top of the phone it is a loose sensor mine did that.... also download the sensor tester and you can see when it works and when it does not work. it took me 45 min to convince the tech that it was a loose connection
Robbyworkman1995
