1. Cheryl H's Avatar
    I cannot get my phone to make a notification sound when I get a text message. Also, the blue light will not flash. I cleared the cache, I reset the sound to a different sound to see if that would work. Nothing works! Help!
    02-20-2014 03:59 PM
  2. Gekko's Avatar
    try switching to Hangouts for Text Messaging.
    Hangouts (replaces Talk)
    Google Inc. - February 6, 2014
    Communication
    https://play.google.com/store/apps/d...oid.talk&hl=en
    02-20-2014 04:04 PM
  3. Cheryl H's Avatar
    Will that make a notification sound?! I am worried about missing text messages.
    02-20-2014 04:07 PM
  4. Golfdriver97's Avatar
    Yes. And in settings you can change it to what you wish.
    02-20-2014 04:25 PM
  5. Cheryl H's Avatar
    It turns out I did have hangouts turned on - it still is not making a sound or a flashing blue light when I get a message.
    Any other advice?
    02-20-2014 06:28 PM
  6. ShaggyKids's Avatar
    If you have your Bluetooth on try turning it off and testing that way.
    Deb from my Note 3
    02-20-2014 08:56 PM
  7. sarkycow's Avatar
    Any other advice?
    I had this issue when I had both hangouts and the stock sms app going/on at the same time. I disabled hangouts and haven't had a problem with the stock sms app since.
    02-20-2014 09:46 PM
  8. yarnsrj's Avatar
    Worth a shot, did you check to see that your notification sound is turned up within the overall volume settings?
    from my "Note 3" on Tapatalk
    02-21-2014 01:05 PM
  1. KitKat: no SMS notifications
    By KSDroid01 in forum Verizon HTC One
    Last Post: 04-17-2014, 09:34 AM
  2. Stock messaging app problems
    By PastorDroid in forum Samsung Galaxy Note 3
    Last Post: 02-20-2014, 07:50 PM
  3. Pebble Causing Sound Artefacts?
    By fade2black101 in forum Samsung Galaxy Note 2
    Last Post: 02-20-2014, 06:10 PM
  4. Music not sound on SD card using Walkman app
    By Flipcjl in forum Sony Xperia Z1
    Last Post: 02-20-2014, 12:59 PM
  5. notification light on back
    By techie5 in forum LG G2
    Last Post: 02-20-2014, 12:02 PM
