Results 1 to 22 of 22
Like Tree3Likes
  • 1 Post By SancLunatic
  • 1 Post By karsdroid
    Default FoxFi/Free Wifi on the Verizon Note 3
    Has a workaround been found yet for the latest update of the Verizon Note 3 to be able to get free wifi or use apps like Foxfi? The home button trick has been patched in the December update. I don't feel like paying for free wifi. I am considering rooting but first I want to find out if any way has been found without rooting.
    ElviraL likes this.
  2. #2
    Default Re: FoxFi/Free Wifi on the Verizon Note 3
    Foxfi works without root. Just cancel if Verizon warning comes up then turn uncheck Foxfi and try again. Works great for me.
    Sent from my SM-N900V using AC Forums mobile app
  3. #3
    Quote Originally Posted by SancLunatic View Post
    FoxFi works fine after the Dec update.
    Sent from my Xoom using Tapatalk
  4. #4
    Sorry if this is a dumb question, but what does FoxFi do that VZW's built-in Mobile Hotspot app? Don't you pay for data either way?
    I understand on Sprint with unlimited mobile data that does NOT including tethering there is an advantage to FoxFi or similar apps (i.e. unlimited tethering data at no extra charge), but on VZW you pay for data whether it's destination is the phone itself or passed-through to another device.
  5. #5
    The point is that some legacy data plans do not include tethering. You have to pay for it at an additional charge
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  6. #6
    Foxfi working for me on verizon..
  7. #7
    Default
    FoxFi working for me as well on Verizon. As someone else said, you just have to back out of the subscription screen.
    The big question is now will they be able to re-engineer after Kit Kat. They've always been able to do it in past updates. Sometimes it takes a month for specific models and carriers. But this is the first time that I've seen them throw up a warning screen about the possibility that it won't work worth a specific upgrade, i.e. Kit Kat. I wonder if they know something that we don't.
  8. #8
    For that reason I am not looking forward to kit kat.
    Good to know that Verizon seems to always be last on updates, hopefully Foxfi figures out a fix!
  9. #9
    When is the kit kat 4.4 OTA supposed to be released here in the US?
  10. #10
    Nobody knows
  11. #11
    I'm using it now. I do have to try 3 times before it works though.
    Sent from my Samsung Galaxy Note 3 via Android Central App
  12. #12
    @theCyberGuy: By "try 3 times", do you mean check the "Activate Hotspot" checkbox 3 times?
    Because no matter how many times I try to check that box in FoxFI on my Motorola Droid RAZR M, each time it pops up a dialog with the message, "Your carrier has blocked WiFi mode in latest phone update. Please use USB mode or Bluetooth mode instead." and only an OK button to dismiss it with.
    This is unfortunate since in almost every other way, KitKat (4.4.2) is superior to Jelly Bean (4.1.2) from which it was updated: faster and more responsive, lower battery usage, lower memory usage, and so far I haven't found one incompatibility (aside from this).
  13. #13
    I was going to buy a Note 3 today. Will Foxfi work out of the box or do I have wait until foxfi is updated?
    THX
  14. #14
    Quote Originally Posted by Barry Test View Post
    THX
    foxfi website says that the note 3 on 4.4 is now supported....i'm in the middle of the download and it will be the first thing i test out. i use foxfi all the time.
    shortwave8669 likes this.
  15. #15
    so foxfi now has me manually go to settings and turn on the mobile hotspot feature and then connects. it was a little disconcerting as i expected and verizon popup telling me to subscribe, but nothing popped up. mobile hotspot turned on and says im connected through the foxfi network name.
  16. #16
    Default
    Does anyone else keep getting a triangle in the notification bar after kitkat, has to do with credentials I think. I'm getting it about every 10 min.
  17. #17
    Quote Originally Posted by alxarambula View Post
    Might be Picasa wanting your credentials when you go into your gallery. There are a few threads that show you how to get rid of it.
  18. #18
    Quote Originally Posted by karsdroid View Post
    Same thing here but it works fine...
  19. #19
    the triangle comes up whenever i started up foxfi to warn of their credentials...once i dismissed it it didn't come back....
  20. #20
    BT nor WiFi works on KitKat and VZW Note 3
  21. #21
    Quote Originally Posted by DocWyeth View Post
    Not according to multiple reports. Some have reported it working just fine.
    Some people also had problems getting it to work on JB as well. It was just user misunderstanding.
  22. #22
    Works just fine on my VZW Kit Kat Note3.
    Sorry to hear you are having problems.
  1. KitKat 4.4.2 Running Great on the Epic 4G Touch --- Yes, it's true!
    By drk65 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-02-2015, 07:41 PM
  2. "s-pen detected" missing in the notification bar
    By Uschiekid in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 07-28-2014, 04:27 PM
  3. AT&T Agent somewhat confirmed a release date for the S5
    By AlphaVictor87 in forum Samsung Galaxy S5
    Last Post: 02-23-2014, 09:30 PM
  4. At&t Note 3 $100 on contract from Frys b&m
    By dpham00 in forum AT&T Samsung Galaxy Note 3
    Last Post: 02-21-2014, 04:02 PM
  5. Replies: 0
    Last Post: 02-21-2014, 03:36 PM
