Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By tannerrblake
  • 1 Post By markag6
    Emperor's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Neo Hybrid Frame for Note 3
    I purchased the Spigen Neo Hybrid for my Note 3 and it is great. If you are familiar with the case then you know the bumper/frame come in different colors. Does anyone know where I can purchase the bumper/frame without have to buy a complete new case? I emailed Spigen a few days earlier, but no response yet.
  2. #2
    markag6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Neo Hybrid Frame for Note 3
    You probably have to buy a whole new case. Spigen or ebay might be your best bet. I just bought the same case (in silver) for my note 3. I can't wait for it to get here.
    Emperor's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the silver one and it isawesome. I found the bumper/frames for the S3 and S4 on Amazon. Just keeping my fingers crossed for the Note3.
  4. #4
    alxarambula's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the gold one looks sweet. Don't know where to buy the bumper on it own either.
  5. #5
    tannerrblake's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I emailed Spigen about this same thing and got this response:
    Thank you so much for contacting us and we appreciate your patience.
    Ill be more than happy to assist you with your question.
    Unfortunately, we do not currently have any plans to create these frames.
    However, we will definitely consider your interest! We are keeping a log of how many people want this product. Thank you for that suggestion.
    I guess what that means is keep emailing them! If enough people want them, there's a chance that they'll start selling them seperately.
    dc5_k20z1 likes this.
  6. #6
    petaf's Avatar
    Posts
    Global Posts
    1,038 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the bright red one!! I'd love to get a silver frame and mix it up!
  7. #7
    markag6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've got the silver neo hybrid. I really like it. Doesn't add extra bulk to the phone and it looks nice.
    Sent from my Galaxy Note 3 using Tapatalk
    sforsyth01 likes this.
  8. #8
    EpicInYourFace's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just buy a fake one for the frame
    Sent from my SM-N9005 using Tapatalk
  9. #9
    patrick1229's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have this case in the yellow, its pretty awesome. I do wish i could switch the frame out to change it up.
    Does anyone notice the buttons for the volume and power being loose? They work fine but seem like they may fall out?
  10. #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by patrick1229 View Post
    Yah I also have that problem
    The buttons wobble
  11. #11
    cwbcpa's Avatar
    Posts
    Global Posts
    1,686 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have that case for the iPhone 5s and the buttons are loose on the case. They work perfectly though. I have not bought the case for my Note 3 yet but probably will. It's a great case. I don't worry about them falling out. I have not heard of that happening.
    Sent from my SM-N900V using Tapatalk
  12. #12
    anon154738's Avatar
    Posts
    Global Posts
    182 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP/ Franco Kernal
    Just got mine today, and I love it. I've never had a case on a phone before but this phone is too big! I'm also worried about the looseness of the buttons but I've not heard of them falling off.
  13. #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The buttons on mine do work perfectly as well. Almost wished i got the gold or metal slate color, but the yellow has definitely grown on me bigtime. Now I'm just waiting for tech armor to replace my ballistic glass screen protector (first one has an imperfection in the glass) and ill be all set!
  14. #14
    alfonso2501's Avatar
    Posts
    Global Posts
    68 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah, mine too. Not a big deal.
  15. #15
    Hurleygm's Avatar
    Posts
    Global Posts
    350 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have this case too. It's the only case I have liked on any phone I have ever had.
    The buttons are loose but don't feel as if they are going be an issue. I too wish I could change it up. I have the silver, but would love to switch out with yellow and red every now and then.
  16. #16
    Raptor007's Avatar
    Posts
    Global Posts
    6,963 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Its pretty lame they don't offer the frame separately, like they do on the Slim Armor case which is interchangeable.
  17. #17
    dc5_k20z1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock FP5
    Quote Originally Posted by tannerrblake View Post
    I've been searching for the frames separately but never had any luck. Thanks for sharing.
  18. #18
    xderiwx's Avatar
    Posts
    Global Posts
    348 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Only thing I dislike about it is the way the back picks up oils. It seems to not be able to be cleaned off also. Anyone know how to clean these and remove hand oils from the back/black tpu piece?
  1. Suggest Headphones (wired & wireless both) for nexus 5
    By vitrag24 in forum Nexus 5 Accessories
    Last Post: 02-27-2014, 05:00 AM
  2. Note 3 stuck at the logo screen
    By Midomi333 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 02-26-2014, 05:03 AM
  3. errors for playstore version 4.2.0
    By Cameron Hayes in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-23-2014, 12:52 AM
