1. jmf283's Avatar
    I love my note 3 from Verizon. The only problem is the volume is inconsistent. It'll play at the volume I set, then get really low, after a few minutes it'll go back to normal, then restart the cycle. I notice it when I'm just playing it through the phone's speaker and I notice it when Bluetooth streaming. I haven't tried through head phones.
    I've tried clearing the cache. I've tried closing all open apps. I've tried rebooting the phone. I've also tried A2DP from the play store. I'm not rooted and would only consider it as a last resort.
    I tried searching through various forums and Google searches but have come up empty.
    Anyone else experiencing this?
    02-24-2014 07:24 AM
  2. Johnly's Avatar
    While I have not had this issue, I read that if you disable the equalizer on google music, that is a workaround. Maybe someone else here has a better place to start with that issue. Good luck.
    Sent from my SM-N900V using Tapatalk
    jmf283 likes this.
    02-24-2014 07:56 AM
  3. jmf283's Avatar
    Thanks! It literally worked instantly once I turned the eq off.
    Bummer though...playing through the speaker I don't hear a difference, but I can hear a huge difference while Bluetooth streaming
    I appreciate the advice
    Johnly likes this.
    02-24-2014 03:59 PM
  4. Bluelens's Avatar
    I am having the same issues listening through the Google Music app with me headphones. I switched over to the Samsung Music app to see if the same thing was happening and I didn't notice it on my commute home yesterday. I will try to EQ trick like Johnly mentioned too.
    02-25-2014 09:33 AM
  5. beh's Avatar
    I am using an app called EQualizer (Play Store) and have never had the volume changing issue. It also changes the presets to the type of music playing automatically and changes as necessary on the fly for each selection playing.
    02-25-2014 11:19 AM
  1. Bluetooth headset button inconsistent
    By crxssi in forum Google Nexus 5
    Last Post: 10-25-2014, 11:39 PM
  2. Unsafe Volume Warning After KitKat Update
    By badadjective in forum Verizon HTC One
    Last Post: 08-09-2014, 12:40 PM
  3. volume issues
    By kimmybels in forum T-Mobile Samsung Galaxy S4
    Last Post: 02-24-2014, 06:24 PM
  4. Replies: 0
    Last Post: 02-21-2014, 03:56 PM
  5. alarm volume
    By iRevo in forum Samsung Galaxy SIII I9300
    Last Post: 02-18-2014, 02:19 AM
