03-06-2014 10:31 AM
48 12
tools
  1. aspenedelen's Avatar
    I bought this N3 four months or so ago and just within the last month I have noticed a slow gown with this device.
    Just today when I went to open Contacts to call someone it took at a minimum 8 seconds for the contact to open up.
    I try and Defrag this unit once a week, have approx 70 apps installed and 1500 contacts. I also try and close out and apps running once day and have just purchased and installed the ZeroLemon 10000mah battery and run 4G with one to two bars here in my house.
    I have noticed when I try and open emails that it takes upwards of ten seconds to open the email if I don't have to close it out then try and reopen.
    Anyone have any advice for me?
    02-26-2014 11:25 AM
  2. aspenedelen's Avatar
    I read on a different thread about getting into recovery mode then wiping Cache.
    I just did this. Anything else I can do to help?
    02-26-2014 12:55 PM
  3. z06mike's Avatar
    That is really not normal at all. After a reboot is it still slow?
    Sent from my SM-N900V using Tapatalk
    02-26-2014 04:29 PM
  4. Spacemaker24's Avatar
    I use Clean Master. One of my favorite things about it is that it displays which apps are hogging the RAM. I've disabled some and uninstalled others. I've had this phone for 5 months and it's always lightning fast.
    Sent from my Galaxy Note 3 via Tapatalk 4 Pro
    02-26-2014 06:37 PM
  5. aspenedelen's Avatar
    It sure is.
    I looked at the app manager in battery and it says that 43% of battery is being used by the screen.
    This ZeroLemon 10000mah battery is on its second full day with a full 100% charge only lasted me from 7:30am thru 9:00pm tonight.
    I took probably 30 phone calls today which lasted combined two hours, wrote a dozen or so emails, sent a few hundred texts, looked at apps for a total of a hour, mobile Web a hour.
    I can't seem to figure out why this insane battery is draining so fast.
    02-26-2014 09:33 PM
  6. z06mike's Avatar
    Download wakelock detetecor and/or gsam battery and see what it causing the drain. I would bet a rogue app is causing the lag.
    weatherlover1 and aspenedelen like this.
    02-26-2014 09:40 PM
  7. aspenedelen's Avatar
    I'll take a look at it. Thanks for the tip!
    02-26-2014 09:40 PM
  8. aspenedelen's Avatar
    Just downloaded! Appreciate the tip with this.
    Could the screen being on high all day be the root cause of the battery drain?
    02-26-2014 09:43 PM
  9. z06mike's Avatar
    Your screen will almost always be the highest percentage of your battery drain. What is your screen on time???
    02-26-2014 09:44 PM
  10. aspenedelen's Avatar
    It times out after two minutes. Is there a way to find out what the total run time is per day?
    02-26-2014 09:53 PM
  11. z06mike's Avatar
    Yes go to settings>general>
    battery and click on each entry. It will give you a breakdown of time for each one.
    02-26-2014 09:55 PM
  12. aspenedelen's Avatar
    7:27:27 today I tbink
    02-26-2014 09:56 PM
  13. z06mike's Avatar
    Post a screenshot!
    02-26-2014 09:58 PM
  14. aspenedelen's Avatar
    Post a screenshot!
    I have the pic but can't figure out how to post it
    02-26-2014 10:04 PM
  15. z06mike's Avatar
    Not sure if you can via the AC app. I use Tapatalk.
    02-26-2014 10:06 PM
  16. aspenedelen's Avatar
    I just posted the pic in a new thread via Tapatalk. Tapatalk wouldn't let me into this thread
    02-26-2014 10:21 PM
  17. aspenedelen's Avatar
    My N3 seems to be slowing down,  can anyone help diagnose?-uploadfromtaptalk1393474954811.jpg
    Here we go
    02-26-2014 10:22 PM
  18. z06mike's Avatar
    That's pretty good. At that rate you will get ~12 hours screen on time!
    02-26-2014 10:30 PM
  19. aspenedelen's Avatar
    The stock battery lasted me a half a day under pretty intense usage. When I upgraded to this Zerolemon battery I expected at least two days of usage but I don't even get one full day.
    Am I just a seriously heavy user of battery hogging apps and that is the way of life?
    02-26-2014 10:33 PM
  20. aspenedelen's Avatar
    One thing is for sure the display is on auto and during the day it is set to the brightest resolution possible. I presume this could be the top issue?
    Do I just need to deal with the brightness much lower throughout the day if I want serious battery?
    02-26-2014 10:36 PM
  21. z06mike's Avatar
    Either you're using the phone A LOT or something is keeping the screen on even when you're not using it.
    02-26-2014 10:49 PM
  22. aspenedelen's Avatar
    Appreciate your help! I am willing to bet it is because I am on this beast all day long.
    Thank you for your feedback
    I'll let you know how it goes tom evening
    02-26-2014 11:08 PM
  23. z06mike's Avatar
    Sounds like a plan! As far as slowing down/lag is concerned is it any better??
    02-27-2014 09:07 PM
  24. aspenedelen's Avatar
    My N3 seems to be slowing down,  can anyone help diagnose?-uploadfromtaptalk1393559671799.jpg
    As you can see my screen is still using crazy amts of power even though I used it less today.
    Longer phone calls today but all around less screen time.
    02-27-2014 09:55 PM
  25. z06mike's Avatar
    So what does your screen on time show? Also how much is Verizon protection using??
    02-27-2014 10:01 PM
48 12
  1. LTE Doesn't Work on my Samsung Galaxy Note 3
    By Kyo Kusanagi in forum Samsung Galaxy Note 3
    Last Post: 10-27-2014, 08:15 PM
  2. Upgrade my phone
    By leozdad in forum Verizon HTC One
    Last Post: 03-01-2014, 12:13 PM
  3. Replies: 12
    Last Post: 03-01-2014, 09:39 AM
  4. Replies: 14
    Last Post: 02-26-2014, 07:14 PM
  5. Factory reset my phone and now app issues.
    By mindlessharley in forum Motorola Droid Ultra
    Last Post: 02-26-2014, 01:27 PM
