Results 1 to 3 of 3
    JoAnne MacKenzie Bratton's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Verizon Note 3: why do I get 1x so much?
    New to Samsung. I have had Motorola Droid RAZR before I upgraded. Usually my signal in my house is 3g and once in awhile a 4g signal. Since I started using this Samsung phone, my signal shows 1x most of the day. Is it the phone or a weak signal from Verizon?
  2. #2
    dpham00's Avatar
    Posts
    Global Posts
    24,795 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Verizon Note 3: why do I get 1x so much?
    Take a look on Verizon's coverage map, does it show 3g or 4GLTE coverage at your house? Also keep in mind coverage is only guaranteed outdoors so test outdoors too. If you aren't getting 1x outdoors then definitely call Verizon
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    ShaggyKids likes this.
  3. #3
    ShaggyKids's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dpham00 View Post
    WOW! I didn't know that! Thank you for the info.
    Deb from my Note 3
  1. Galaxy Note 10.1: Hit some key and now I can't get my keyboard back
    By Grimgrak in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-07-2014, 06:08 AM
  2. Replies: 5
    Last Post: 04-14-2014, 03:48 PM
  3. Getting stuff off Tab
    By grove53 in forum Samsung Galaxy Tab 10-inch
    Last Post: 03-09-2014, 02:16 PM
  4. Replies: 0
    Last Post: 03-08-2014, 03:40 PM
  5. Replies: 0
    Last Post: 03-08-2014, 03:06 PM
