Results 1 to 24 of 24
    Default CyanogenMod 11 4.4.2 KitKat
    I have my Note 3 rooted on 4.3 and also have safestrap installed. Is it possible to flash this ROM?
  2. Thread Author  Thread Author    #2
    Default Re: CyanogenMod 11 4.4.2 KitKat
    I also do not have the developer edition Note 3.
  3. #3
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Qurlee View Post
    All you need is a custom recovery so you should be able to. Can't remember which ROMs SafeStrap is compatible with
    Sent from my Galaxy S4 running SlimKat 4.4.2
    Quote Originally Posted by UJ95x View Post
    I'm sorry, I'm new to all of this. Custom Recovery as in, Clockworkmod? And I didn't know safestrap was only compatible with certain ROMs
  5. #5
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Yeah. CWM or TWRP. SafeStrap is a modified version of TWRP
  6. #6
    I don't think Cyanogenmod is compatible with safestrap.
    Is there a way to put either of those 2 recoveries on a Note 3 that's not a developer phone?
  8. #8
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by SactoKingsFan View Post
    You're right. It's TW-based ROMs only
    Is there anything similar to the ROM that I can flash to my phone? Like Slimkat?
  10. Thread Author  Thread Author    #10
    Default
    I really just want the Google Android system instead of Samsungs. Something less bulky and doesn't clutter my phone with pointless apps.
    Or would it be possible to flash my phone with the developer restore files on odin? Then install CWM?
  11. #11
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    That would be best. There should be full versions of TWRP for the Note 3.
    I recommend SlimKat over CM
  12. Thread Author  Thread Author    #12
    Unfortunately I do not see Slimkat has made one for the Note 3 yet.
  13. #13
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Just saw that. Only available on the N2
    Anthem is supposed to be a great Note 3 ROM
  14. Thread Author  Thread Author    #14
    Not for Verizon lol. I think I'm going to try out this Eclipse ROM for the Note 3 should be interesting.
  15. #15
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Didn't know you were on a VZW Note 3. My bad
    Eclipse was decent when I used it, but it was ported from the Verizon S4.
  16. Thread Author  Thread Author    #16
    Last question I think, or I hope lol.
    When installing a ROM should I make a virtual ROM or just flash it over the Stock?
  17. #17
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    You can't flash it separately from the stock ROM. It overwrites that.
    Make a nandroid backup before you flash a ROM though
  18. #18
    Is it possible to turn a vzw n3 into a developer version by flashing?
    Sent from my SM-N900V using Tapatalk
  19. #19
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default
    Quote Originally Posted by Imiz Dashiz View Post
    Nope.
    The dev edition's bootloader can be unlocked without voiding warranty. If you flashed anything on yours, you would lose warranty
  20. Thread Author  Thread Author    #20
    Nope.
    Voiding warranty doesn't bother me a single bit. I just want to be able to use what I want. I would love have CWM Recovery on my phone instead of using safestrap.
  21. #21
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    OK, but either way, you can't make it a dev edition. If you are on 4.3, there should be a working CWM/TWRP
  22. Thread Author  Thread Author    #22
    I'll have to do more research then cause I haven't found anything but safestrap.
  23. Thread Author  Thread Author    #23
    I guess I have found a Philz Touch Recovery.
  24. #24
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Philz Touch works too, but I'm not very familiar with it. Still a better option that SafeStrap though
  1. Galaxy S4: SD CARD Issue in KITKAT update
    By sunny sharma13 in forum Samsung Galaxy S4
    Last Post: 09-17-2015, 05:51 PM
  2. Replies: 3
    Last Post: 03-11-2014, 05:38 PM
  3. Did KitKat Eliminate Music Search?
    By CoMoNexus in forum Google Nexus 4
    Last Post: 03-11-2014, 01:18 PM
  4. Replies: 1
    Last Post: 03-11-2014, 10:51 AM
  5. Replies: 1
    Last Post: 03-11-2014, 10:04 AM
