Results 1 to 13 of 13
    Default Verizon Note 3: No USB after 4.3 update.
    I bought the note 3 week of launch in October. December I bought the Samsung smart dock. HDMI, audio & all 3 usb ports worked flawlessly. I could use a flash drive, wireless mouse dongle or anything else. I hadn't used the dock in a few weeks but decided to yesterday & to my dismay none, ZERO of the USB ports work. HDMI & sound still fine but nothing for the USB ports. I've had 2 OTA updates since I've had the phone. I was just wondering if anyone else has had this problem. Is there a solution?
    Thank
  2. #2
    AndroidDev01's Avatar
    Posts
    Carrier
    Stock 4.4.2
    Default Re: No USB after 4.3 update.
    Quote Originally Posted by dkwannabe View Post
    Thank
    Try enabling it in settings. It might have been disabled accidentally.
    Can you walk me through how to find these settings?
    Thanks
    I'm not seeing any option to re-enable usb. Can someone please help me out.
  5. #5
    pdub73's Avatar
    Posts
    Global Posts
    322 Global Posts
    delete please
    Attached Thumbnails Attached Thumbnails Verizon Note 3: No USB after 4.3 update.-usb.jpg
    I don't have a PC. The usb ports on the Samsung Smart Dock are the USB ports I'm talking about. Nothing with a computer....
  7. #7
    pdub73's Avatar
    Posts
    Global Posts
    322 Global Posts
    Sorry...didnt read thoroughly
    Sent from my SM-N900V using AC Forums mobile app
  8. #8
    I am also having a hard time getting audio out of the USB charging port using my car dock. It worked after I enabled it when I bought the phone in November, but now it doesn't and I can't find anything in settings for it.
  9. #9
    Have you did a soft reset and cleared the cache since the update. After an update it is always a good idead to wipe the cache. It will not hurt the phone at all.
  10. #10
    Hmmmm. I have not heard of "clearing the cache" on a phone before. Any quick instructions on how to do that? It's odd that there USED to be a setting for USB audio, but I cant find it anymore.
  11. #11
    Still stuck. I have tried every search string I can think of, but there is no mention of this I can find whatsoever. I have an iBolt dock that has one cable that splits the USB port into two, a USB that goes into a charger and a stereo 1/8" plug. Audio USED to come out of the 1/8", but mysteriously wont any more and I can no longer find the setting for enabling the USB audio anywhere on the phone.
  12. #12
    Default Re: Verizon Note 3: No USB after 4.3 update.
    I have the I-Bolt dock and to get audio out of the USB port you have to go into settings. Scroll down to System, select Accessory, and check off Audio Output Mode-use external speakers when phone is docked. Hope this helps
    Sent from my SM-T310 using AC Forums mobile app
  13. #13
    Follow the first set of instructions. The master reset will wipe everything. https://t-mobile.jive-mobile.com/#ji...cuments%2F9049
  1. T-Mobile Note 3: Do NOT download the Android 4.4 KitKat update!
    By FifthElement in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 10-21-2016, 02:42 AM
  2. How Do I Delete the OTA Update and Its Notification Bar Alert/Icon?
    By limoman in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 11-09-2015, 02:04 AM
  3. NO KNOX app on ATT Note 3!
    By pcguys in forum Samsung SAFE and KNOX
    Last Post: 08-10-2014, 03:51 AM
  4. No Voice mail number on SIM
    By thomasmayne in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-22-2014, 03:20 PM
  5. question about new update
    By jfb42 in forum HTC EVO 4G LTE
    Last Post: 03-12-2014, 11:50 PM
