1. Qurlee's Avatar
    I installed CWM on my SM-N900V and I didn't realize I can't do that because of the Verizon block on it. So installed Safestrap and all was good. But now I'm having several force closes after install Jelly Beans ROM B6. I've heard that doing a Factory Data Reset might fix this issue so I tried and I can't because I still have the CWM Recovery installed. Is there a way I can flash back to original in order to do a Factory Data Reset??
    Galaxy Note 3 running Jelly Beans B6
    03-15-2014 07:08 PM
  2. sicario666's Avatar
    Locate and flash twrp recovery. I've had better luck with that compared to cwm
    53N7 FR0M M4 0N3 MAX
    03-15-2014 07:22 PM
  3. Qurlee's Avatar
    None of them are compatible with the Verizon model yet because Verizon has some type of security on it. That's why I'm using safestrap. I'm just trying to get the stock recovery back on there.
    03-15-2014 07:35 PM
  4. Mr. Toad's Avatar
    Sounds like you might have to Odin back to stock.
    Sent from my SM-N900V using Tapatalk
    sicario666 likes this.
    03-16-2014 12:11 AM
  5. Qurlee's Avatar
    I'm going to try that and then re root my device. How do I go about finding a stock ROM for my device?
    03-16-2014 11:21 AM
  6. jackwagon06's Avatar
    SamMobile | Everything for your Samsung Mobile under firmware. Type in your model and download after locating. I have found that most US versions are listed as "UNKOWN" under country. Not sure why that is. You will have to create an account to download the firmware for them however. Its always a good idea to have the stock firmware on hand while playing, and its starting to become the first thing I do once its available.
    Qurlee likes this.
    03-17-2014 01:29 PM
  7. Qurlee's Avatar
    Perfect! Thank you so much
    03-17-2014 05:38 PM
  8. sulla1965's Avatar
    Safestrap is the only recovery you can use to flash roms on the Verizon note 3 due to having a locked bootloader.
    03-17-2014 11:39 PM
  9. jackwagon06's Avatar
    You are welcome, and also see sulla1965's reply about safestrap. It has the TWRP interface and works very well.
    03-18-2014 08:01 AM
  10. Qurlee's Avatar
    Yes I'm running that currently. I just made the mistake of installing CWM. I learned that pretty quick lol
    03-18-2014 11:28 AM
  11. Spiff637's Avatar
    I just did the same thing, and am really happy that I'm not the only one.. Have you been able to recover it back?
    Thanks!
    03-26-2014 08:27 AM
  12. Qurlee's Avatar
    Yes I have. Worked like a charm!
    03-26-2014 06:36 PM
  1. Dropped my GN 10.1 (2014) - now, black screen
    By DrJim2 in forum Samsung Galaxy Note 10.1
    Last Post: 11-07-2015, 07:49 PM
  2. Droidkang rom and custom kernels on the Nexus 5
    By chrispher86 in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 04-09-2014, 09:45 AM
  3. very beginner question - contacts and sending sms messages
    By matannnnn in forum Google Nexus 5
    Last Post: 03-15-2014, 07:38 PM
  4. Media player for mac and android
    By realstreets in forum General Help and How To
    Last Post: 03-15-2014, 12:16 PM
  5. DLNA and ES File Explorer
    By dimm0k in forum Android Apps
    Last Post: 03-15-2014, 12:15 PM
