Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Mr. Toad
  • 1 Post By jackwagon06
    Qurlee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Verizon Note 3: Installed CWM and now it's a disaster
    I installed CWM on my SM-N900V and I didn't realize I can't do that because of the Verizon block on it. So installed Safestrap and all was good. But now I'm having several force closes after install Jelly Beans ROM B6. I've heard that doing a Factory Data Reset might fix this issue so I tried and I can't because I still have the CWM Recovery installed. Is there a way I can flash back to original in order to do a Factory Data Reset??
    Galaxy Note 3 running Jelly Beans B6
  2. #2
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    4,205 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    stock
    Default Re: Installed CWM and now it's a disaster
    Locate and flash twrp recovery. I've had better luck with that compared to cwm
    53N7 FR0M M4 0N3 MAX
    Qurlee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    None of them are compatible with the Verizon model yet because Verizon has some type of security on it. That's why I'm using safestrap. I'm just trying to get the stock recovery back on there.
  4. #4
    Mr. Toad's Avatar
    Posts
    Global Posts
    873 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sounds like you might have to Odin back to stock.
    Sent from my SM-N900V using Tapatalk
    sicario666 likes this.
    Qurlee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm going to try that and then re root my device. How do I go about finding a stock ROM for my device?
  6. #6
    jackwagon06's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Qurlee View Post
    SamMobile | Everything for your Samsung Mobile under firmware. Type in your model and download after locating. I have found that most US versions are listed as "UNKOWN" under country. Not sure why that is. You will have to create an account to download the firmware for them however. Its always a good idea to have the stock firmware on hand while playing, and its starting to become the first thing I do once its available.
    Qurlee likes this.
    Qurlee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jackwagon06 View Post
    Perfect! Thank you so much
  8. #8
    sulla1965's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Safestrap is the only recovery you can use to flash roms on the Verizon note 3 due to having a locked bootloader.
  9. #9
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You are welcome, and also see sulla1965's reply about safestrap. It has the TWRP interface and works very well.
    Quote Originally Posted by sulla1965 View Post
  10. Thread Author  Thread Author    #10
    Qurlee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes I'm running that currently. I just made the mistake of installing CWM. I learned that pretty quick lol
  11. #11
    Spiff637's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just did the same thing, and am really happy that I'm not the only one.. Have you been able to recover it back?
    Thanks!
  12. Thread Author  Thread Author    #12
    Qurlee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes I have. Worked like a charm!
  1. Dropped my GN 10.1 (2014) - now, black screen
    By DrJim2 in forum Samsung Galaxy Note 10.1
    Last Post: 11-07-2015, 08:49 PM
  2. Droidkang rom and custom kernels on the Nexus 5
    By chrispher86 in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 04-09-2014, 10:45 AM
  3. very beginner question - contacts and sending sms messages
    By matannnnn in forum Google Nexus 5
    Last Post: 03-15-2014, 08:38 PM
  4. Media player for mac and android
    By realstreets in forum General Help and How To
    Last Post: 03-15-2014, 01:16 PM
  5. DLNA and ES File Explorer
    By dimm0k in forum Android Apps
    Last Post: 03-15-2014, 01:15 PM
