Results 1 to 5 of 5
    Eric Bentley's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default help! my note 3 turned into a brick
    it was more than 50% charged, and when i took it out of my pocket, it was dead as a brick. it won't turn on. no red light nothing. i plugged it into the charger, and still nothing. it is a new phone, bought just 6 weeks ago. help!
  2. #2
    Vudumedic's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    RunnyMik/stock
    Default Re: help! my note 3 turned into a brick
    Pull the battery and the SIM card, wait 45 seconds then put them back in. Try booting up and see what happens.
    dpham00 likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    that worked!! thanks so much!! what do you think the problem was?
  4. #4
    jackwagon06's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PFM
  5. #5
    b pennoyer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi,
    Exact same thing-bought Galaxy Note 3 about 6 wks ago-was charged- installing an app made it a brick. NOTHING . Call the 800 verizon customer support. They'll try all the usual- holdiing the power/volume down at same time- if nothing boots it up ask for a new phone- INSIST- my galaxy has been wack since I bought it- the rep was very good- finally decided to send a replacement in the mail- you'll need to return the dead phone to them within 5 days. Good Luck!
    Barb
  1. Can my Carrier refuse service for rooting......
    By Irisheagle in forum Verizon Samsung Galaxy S4
    Last Post: 09-15-2014, 10:25 AM
  2. help please - screen flickering issue
    By Gavvykinz in forum LG G2
    Last Post: 04-17-2014, 02:52 AM
  3. Turn off speaker when using a bluetooth
    By hmfoster in forum Verizon Droid DNA
    Last Post: 03-24-2014, 11:12 AM
  4. Nexus 7 turns on when charging
    By Hugo Barbosa in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-17-2014, 11:04 AM
  5. Help! JellyBAM Can't Connect to Camera!
    By SheldDaaady in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 03-16-2014, 07:04 PM
