05-30-2014 11:44 AM
28 12
tools
  1. twick75's Avatar
    Has anyone had their Note 3 refuse to stay connected to 4G? I am not on the fringe of a 3G/4G line, yet in the past few days I've noticed my phone is always in 3G, while my wife can be sitting right next to me in 4G. I haven't had a problem until just recently.
    Any ideas to help get me back in the fast last?
    04-01-2014 07:44 PM
  2. dpham00's Avatar
    Have you tried to restart the phone?
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    04-01-2014 07:45 PM
  3. twick75's Avatar
    Yes I have tried a couple shutdowns and even battery pulls. It may stay in 4G for a short time, then capooey, right back to 3G. It doesn't appear it is trying to jump back and forth either.
    Thank you for the suggestion.
    04-01-2014 07:48 PM
  4. burwil's Avatar
    My note 3 goes to 3G at least once every other day. Never happened with my note 2. Fix it by toggling airplane mode.
    Sent from my IPad Air via Tapatalk
    04-01-2014 07:56 PM
  5. z06mike's Avatar
    Go to settings > more networks > mobile networks: select LTE/CDMA instead of global and see if that fixes the issue.
    Sent from my SM-N900V using Tapatalk
    04-02-2014 10:41 PM
  6. twick75's Avatar
    Thanks for the help. I went to the Verizon store and they replaced the sim card and the 4G is working again.
    Thanks again.
    dpham00 likes this.
    04-03-2014 04:08 PM
  7. BBSeattle's Avatar
    Very cool! Glad it was that simple.
    I have had to do the same with a couple of phones in the past.
    I would have mentioned it but just stumbled on your post.
    Thanks again.
    04-04-2014 09:38 AM
  8. dpham00's Avatar
    Glad it was a simple fix
    04-04-2014 09:48 AM
  9. hawkeye680's Avatar
    Mine has been doing that off and on this week as well. I assumed it was network issues.
    This is on a newer SIM too.
    04-04-2014 10:47 AM
  10. HolyBuckeye's Avatar
    my phone has just recently been dropping to 3G in certain areas that I always got 4G...when I'm in the gym, if I take 3 steps over it will go back into 4G, then another few steps, drops to 3G, also noticed when driving in my town, I'd be in 3G at times, just started doing this last week, I've had the phone since February, no issues before then
    Verizon said I should try to pull the SIM card and put it back in, what do you guys think? Will that screw anything up?
    05-10-2014 09:21 AM
  11. bassjo's Avatar
    I've had my phone N3 doing that for a while. The first time I took it to a VZW store they replaced the sim card. It seemed to work for a bit. Then when it started doing it again, they suggested I factory reset my phone... Okay fast forward to yesterday, I walk into a corporate store in a DENSE 4G area with no data connection. I told the about the fixes you all have mentioned here, they contacted Samsung who said that it was the antenna so they're sending me a new phone, should arrive on Monday.
    05-10-2014 04:35 PM
  12. hawkeye680's Avatar
    Finally gave up and called in this morning. Is Verizon sending new replacements or refurbs right now? What did you get, bassjo?
    05-13-2014 08:42 AM
  13. dpham00's Avatar
    It won't hurt to try. It has fixed my connection problem before, though my problem is sometimes 4GLTE slows down, and pulling the sim fixes it temporarily.
    05-13-2014 09:20 AM
  14. twick75's Avatar
    I too have been experiencing the 3G/4G back and forth. It hasn't been a big enough issue, as of yet, that I ventured into the ole Verizon store. I may try the sim card pull if it persists and escalates to the annoying phase. Till then steady as she goes.
    Think I'll push the download button on the upgrade........wish me well. UGH!
    05-13-2014 05:43 PM
  15. HolyBuckeye's Avatar
    I'll pull it and see if anything happens, if not, may walk into the store and just see what they say
    just had another incident today, I was sitting in a restaurant, look at my phone, shows 3G, I get up, walk about 15 steps, get 4G, go back to seat, 3G
    05-13-2014 07:30 PM
  16. HolyBuckeye's Avatar
    It's gotten worse as when I came home today I noticed my phone was in 3G. I've never had any problems anywhere close to my house. I went ahead and pulled the SIM and reinsert it, we'll see if that helps, heading to the gym soon (where I've been getting dropped a lot), if problems persist, I guess my next move is to go into a Verizon store??
    05-16-2014 01:14 PM
  17. HolyBuckeye's Avatar
    Going to go into the a verizon store to get a new SIM to see if that helps. Nothing should change with a new sim, right? (like my unlimited data, etc)
    05-19-2014 11:40 AM
  18. dpham00's Avatar
    Correct nothing would change with the new sim.
    05-19-2014 05:14 PM
  19. HolyBuckeye's Avatar
    So new Sim card doesn't seem to helping matters, any one have any other ideas what I could do next?
    Sent from my Samsung Galaxy Note 3
    05-24-2014 06:58 PM
  20. TimThompson05's Avatar
    Mine has been way worse with 1X or no signal. Put in a service call to Samsung to repair the antenna issue.
    05-24-2014 10:24 PM
  21. dpham00's Avatar
    You can also contact Verizon for troubleshooting and a replacement.
    05-25-2014 09:50 AM
  22. TimThompson05's Avatar
    I bought it at Best Buy without a contract with no insurance. So I have to rely on the warranty.
    05-25-2014 02:16 PM
  23. dpham00's Avatar
    Verizon would probably still honor warranty service, provided that it is currently active on the Verizon network.
    05-26-2014 10:11 AM
  24. TimThompson05's Avatar
    I already tried. They said the way BB activated it doesn't give it a warranty with Verizon. So I'm mailing it to A
    Samsung tomorrow when UPS opens.
    05-26-2014 02:26 PM
  25. HolyBuckeye's Avatar
    Looks like Verizon is gonna send me a replacement.. Dunno if I want to do that, or if I just want to move to a new phone.. May go to HTC m8
    05-26-2014 03:00 PM
28 12
  1. Samsung S4 - Beauty Face edit mode NOT WORKING
    By newandroiduser416 in forum General Help and How To
    Last Post: 05-15-2015, 07:00 AM
  2. Wi-fi not working on RAZR HD
    By lkct01234 in forum Droid RAZR HD
    Last Post: 04-09-2014, 10:17 PM
