04-26-2014 04:08 PM
37 12
tools
  1. zaydabarber's Avatar
    No kit kat - per gottabemobile.com
    At&t Galaxy note 3 & Galaxy Gear & Tab 2 10.1
    04-03-2014 11:15 PM
  2. jeremy81's Avatar
    No kit kat
    That's not what the blog says if you read it fully. The have a misleading title to a paragraph in there and if you read it completely its pretty clear that they don't know what they are talking about. Also, this site issues almost the same articles literally every day.
    04-03-2014 11:28 PM
  3. BBSeattle's Avatar
    It would seem strange considering that the N3 is receiving the update with other carriers.
    I do not recall updates being excluded based on carrier but more based on model.
    04-04-2014 10:36 AM
  4. Spacemaker24's Avatar
    Misleading thread title. Mods should delete.
    Sent from my Galaxy Note 3 via Tapatalk 4 Pro
    04-04-2014 11:20 AM
  5. pdub73's Avatar
    VZW has been known to skip incremental updates like instead of giving us the seemingly "buggy" 4.4.2 they will wait til 4.4.3...but until I hear official word I would ignore this post...
    Sent from my SM-N900V using AC Forums mobile app
    04-04-2014 03:51 PM
  6. Premium1's Avatar
    Wouldn't be surprising to wait for 4.4.3 seeing how buggy 4.4.2 is on note 3 models. I still think Verizon will push 4.4.2 to the note line though.
    04-05-2014 09:26 AM
  7. atrain311qes109's Avatar
    I'm sorry, your avatar just distracts me...
    LET'S GO PENS!!!!!!!!!!!!!!!!!!!
    04-05-2014 11:51 AM
  8. phathands's Avatar
    That site is one of the worst click bait traps. Best to ignore anything they post.
    I second the vote for mods to delete this post.
    please back away from the screen
    anon8380037 likes this.
    04-07-2014 02:27 AM
  9. ShaggyKids's Avatar
    I just got a pop up message on my Note 3 that KitKat blocked my SD card. Apparently the upgrades are happening silently because I never got any notification ahead of time. My About Phone now says 4.3 instead of 4.1.2.
    Time to hit the threads that will help me be able to use my SD card again. I am not happy if this is the case.
    Deb from my Note 3
    04-07-2014 03:00 AM
  10. onewac's Avatar
    4.3 is jelly bean not kit kat. Kit kat is 4.4.2. With kit kat and the sd cards, it has changed how the permissions are used on apps. As I understand it, permissions can only work with the app they are associated with and they can not tap into any other app to snoop around. FYI if you have movies on google play you can download them to the sd card for offline viewing so it will free up your internal memory. On my 12.2 note pro, kit kat is really nice, My note 3 that I just got two days ago is running 4.3 jelly bean. FYI I moved some movies, photos and doc from my mac laptop to a usb thumb drive and then plugged the thumbdrive into the note 3 and the 12.2 using a micro plug to OTG. Everything worked great for viewing or moving to the device itself. That is great for me because I was getting really ticked off with the apps etc not moving to the sd card from the device such as my kindle app, movies etc. Don't know why the kindle app can't be moved to sd card, I could do it before but now the move to sd card option is grayed out.
    04-07-2014 03:13 AM
  11. ShaggyKids's Avatar
    4.3 is displayed in About Phone. The message said something about KitKat having disabled my SD card.
    Deb from my Note 3
    04-07-2014 03:19 AM
  12. fofjjsr's Avatar
    Deb from my Note 3
    KitKat is 4.4 so you must be having some other issue.
    04-07-2014 08:56 AM
  13. ShaggyKids's Avatar
    That's not the only "issue" seems my Tapatalk isn't working right anymore either. I can't get to my favorite forums - used to pop up by default - not able to find it in the settings. Can't subscribe or unsubscribe to posts either. Can't get around in it like I used to, stuff's missing and I miss my Tapatalk! Ugh.
    I wish I could have thoroughly read the msg that popped up ref KitKat but as I turned my phone to "upright" the message disappeared. I only caught that KitKat disabled my SD card. Although so far I think the SD card is still working? What's a good test to find out?
    04-07-2014 09:18 AM
  14. zaydabarber's Avatar
    Are u getting kit Kat update
    samsung note 3 & Tab 2 10.1
    04-07-2014 11:16 AM
  15. ShaggyKids's Avatar
    I'm told it's not KitKat because its not 4.4 whatever its 4.3 and that's supposed to be jelly bean.
    Deb from my Note 3
    04-07-2014 01:17 PM
  16. lovecars's Avatar
    Sounds like a virus or some other malware on your phone. Check what you installed lately before you started having problems.
    04-07-2014 01:53 PM
  17. recDNA's Avatar
    I would pay vzw 50 bucks NOT to push Kitkat to my phone.
    Sent from my SM-N900V using Tapatalk 2
    04-07-2014 02:00 PM
  18. ShaggyKids's Avatar
    Maybe if you add a whole bunch of zeros after the number 5 they might consider it.
    Deb from my Note 3
    04-07-2014 02:20 PM
  19. ShaggyKids's Avatar
    Well, I found out that the problem with Tapatalk is that it logged me out when I rebooted my phone. I logged in again and its fine. The message has not appeared again so I guess for now unless I have any more problems or it shows up again I'm going to chalk it up as a glitch are figment of my paranoid imagination. So far my sd card does not seem to have been affected at all.
    Deb from my Note 3
    04-07-2014 02:24 PM
  20. bihjack216's Avatar
    Deb from my Note 3
    The note 3 shipped with 4.3 no way you had 4.1.2
    04-07-2014 09:46 PM
  21. n8ter#AC's Avatar
    Must be talking about a Note 2
    Sent from my Galaxy Note 3 using Tapatalk
    04-11-2014 05:50 AM
  22. recDNA's Avatar
    I hope you're right
    04-12-2014 11:26 AM
  23. invincible1914's Avatar
    I actually don't want kit kat messing up my sd card and blocking foxfi. I'm good on 4.3
    04-12-2014 08:17 PM
  24. krayzeesmoke's Avatar
    I just bought my note yesterday (changing stuff over from s3 now) at best buy and the Samsung rep was saying by next month it will roll out
    Posted via a tiring Galaxy S3
    04-13-2014 12:48 PM
  25. ShaggyKids's Avatar
    Phone Store Rep 101: Never trust a phone store rep 100%.
    Deb from my Note 3
    04-13-2014 02:21 PM
37 12
  1. [FREE] [GAME] Storm the Ship
    By ahovancsak in forum Android Apps
    Last Post: 07-04-2014, 12:40 AM
  2. Galaxy S5: Simultaneous voice and data over 3g on Sprint?
    By eyecon82 in forum Samsung Galaxy S5
    Last Post: 04-04-2014, 11:47 AM
  3. Replies: 2
    Last Post: 04-04-2014, 08:36 AM
  4. Bootloader will be locked
    By adlebo in forum Samsung Galaxy S5
    Last Post: 04-03-2014, 10:09 PM
