How well does Pocket play with the Note 3?
kawana72
160
4
Hello all. I tried searching for this but nothing came up. I switched over to a Note 3 from the Razr Maxx where Pocket was next to unusable.The issue with the Maxx was a storage issue when the Maxx updated to 4.0 that kept android.process.media running after a restart of the device. My question is, has anyone had any issues with Pocket not playing nicely with the Note 3? I really liked Pocket and would like to use it again, but I'm a little hesitant to pull the trigger.
Mr. Toad
875
I am using it and don't have any big issues. The only problem I have encountered is if I quickly pocket 2 links the pop-up menu on the bottom of the screen dies not go away. I FC pocket to make it go away.
I recommend installing it and trying out out for a couple days.
Sent from my SM-N900V using Tapatalk
Cy3berOdyssey
