Nevermind. Was just trying to help but apparently that was lost to you all. And thanks whoever deleted one of my replies. I guess I'll delete this then.
Sent from my SM-N900V using AC Forums mobile app
I understand that you're trying to help. It's quite obvious that you put a lot of work and time into your blog post. It's also obvious that there are numerous people who really want this upgrade.
On the other hand it also sounds like any other upgrade, it's going to mess some things up while attempting to fix other issues. For some people it will be a good thing for others it will not.
I'm hoping that the time that verizon is taking to release it, that they're working on getting the bugs out that people have been complaining about. As it stands right now, I have a few issues with my phone although overall it's a great phone. Unfortunately for me, my biggest problem goes back all the way to my S3 and still is not fixed on my Note 3 which is several phones later because I had some replacement phones in the mix with the same problem. I don't foresee KitKat fixing this issue. Samsung keeps ignoring the problem. So if it's going to mess up my phone elsewhere I prefer to not have it. I like the way my SD card works right now and it seems there is a possibility the upgrade will mess that up for me.
To anyone who was offended by my previous post in this thread you have my sincere apologies.
Deb from my Note 3
