It seems the source has been refuted after today.
Sent from my SM-N900V using Tapatalk
I don't know what u mean?
Oh, I see thanks. I don't want Kitkat anyway.
I hope that there aren't any problems with the update since Verizon takes so long to release the update
I look forward to Google Wallet working, simply because it should. I don't know how much I will use it but it would be nice to have it available. I hope PDA Net writes a fix for losing Foxfi, I use it all the time. If I had to choose between gaining Google Wallet and losing Foxfi it's not even a contest. Like many updates, it will probably not be an option and they will probably force it on us eventually.
I think I read on xda that google wallet works, but not the tap to pay functionality.
The Tap and pay is a function of Google Wallet, so until that works I don't consider it fully functioning. I set up Google wallet, have a credit card on it, all ready to tap and pay when it starts working. I refuse to use the Verizon / ATT / Tmobile tap and pay app since they will not allow competition on their network / devices. However they are blocking Google Wallet from working, it has me boycotting their tap and pay. Even if it worked better, I would refuse to use it. Interesting that Sprint is not in on the ISIS app, and Google wallet with tap and pay works fine on their phones and network. Isis (mobile payment system) - Wikipedia, the free encyclopedia
Google wallet requires kit kat after April 14th. Google Wallet's tap-to-pay feature will require Android 4.4 KitKat starting April 14th
I just read where Foxfi will now work with the Kit Kat update, and that was one of my main concerns. If I gain google wallet and don't have any bad side effects all the better.
Yea plus Isis you can only use American express card and not visa which I have.
You are incorrect. I have my regular American Express card, a Chase Visa, and a Wells Fargo Visa all loaded to my ISIS account and I used them all interchangeably with no problem.
