My car stereo only has a 3.5mm aux input jack. I currently connect the Note 3 via a 3.5mm cable plugged into the Note 3's headphone jack and it sounds fine.
However, I'm wondering if I'll get better sound by getting a Bluetooth receiver. The receiver will pick up the sound from the Note 3 via Bluetooth, then feed it to the car's aux in.
Or is there very little difference between the two, as far as sound quality is concerned?
Thanks!
Thanks!
