Results 1 to 9 of 9
    Default connecting to car's aux in, which will sound better? Bluetooth or headphone out?
    My car stereo only has a 3.5mm aux input jack. I currently connect the Note 3 via a 3.5mm cable plugged into the Note 3's headphone jack and it sounds fine.
    However, I'm wondering if I'll get better sound by getting a Bluetooth receiver. The receiver will pick up the sound from the Note 3 via Bluetooth, then feed it to the car's aux in.
    Or is there very little difference between the two, as far as sound quality is concerned?
    Thanks!
  2. #2
    aslondon's Avatar
    Posts
    Global Posts
    47 Global Posts
    Default Re: connecting to car's aux in, which will sound better? Bluetooth or headphone out?
    My receiver does both and I can barely tell the difference. Now, its a jeep so probably not the best test in the world.
    Al
  3. #3
    Miami1683's Avatar
    Posts
    Global Posts
    97 Global Posts
    Usually plug in is better than BT but it depends on your ears
    Sent from my SM-N900V using Tapatalk
  4. #4
    I've used both and in most cases direct plug in works better. At the same time Bluetooth tech has come a long way and sounds pretty damn good.
  5. #5
    TheMacs's Avatar
    Posts
    Global Posts
    604 Global Posts
    Wired will be better, but you likely will not be able to tell. Some people with more sensitive hearing may be better able to. Test it out.
  6. #6
    pathfinder3's Avatar
    Posts
    ROM
    CM7 Nightly
    I find connecting via blue tooth to my car radio to be very convenient. Not only does it sound good for music, but I also take advantage of hands free speaker phone, automatic contacts list upload, and text to speech that are all done thru blue tooth connection. Only wire attachment I use is to charge my phone.
  7. #7
    ehosey2's Avatar
    Posts
    Global Posts
    525 Global Posts
    Quote Originally Posted by pathfinder3 View Post
    I am in 100 percent agreement with this. I have my Note 3 connected to my Pioneer AVH-P8400 double din unit that enables all this. Put this all together with premium aftermarket amps, speakers, subs, cables, and professional install and bluetooth audio sounds awesome. I am using Milk Music as my primary streaming service which sounds great utilizing the high quality setting.
    Sent from my Samsung Galaxy Note 3.
    Samsung Galaxy Note 3 and Note 8.0.
  8. #8
    Quote Originally Posted by ehosey2 View Post
    Milk Music Rocks
  9. #9
    Note 3, I have Bluetooth hand-free calling in my vehicle (on-star); however, it does not have a2dp audio profile for streaming music though my car's speakers. Not a problem as i can use standard audio jack and listen to my device. Herein lies my problem. I prefer to use on-star hand-free Bluetooth calling when I'm in my vehicle to answer calls, but when I'm plugged into "headphones" The call defaults to the 3.5mm audio jack. This does not work as no one can hear me. since its not using the Bluetooth of the car, it doesn't recognize a microphone, nor does it when plugged into my car's auxiliary. There a button to broadcast though the headset, but it is unclickable. To talk on the phone i have to either unplug the headset chord, or enable speaker phone. Neither of these options is a viable solution. My previous Motorola phones never had any issues connecting calls to via Bluetooth while keeping mp3 player though audio jack. Is there a solution to this problem.
  1. restarted after a week. its fault or mine?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-27-2014, 12:31 PM
  2. PLEASE Help flashing recovery to my GN3!!!
    By Steven Weatherbuzz in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-24-2014, 06:53 AM
  3. Replies: 0
    Last Post: 04-24-2014, 02:26 AM
  4. How to use Android phone to play blu-ray movies of my pc?
    By MuziTao1126 in forum General Help and How To
    Last Post: 04-24-2014, 02:09 AM
  5. How to delete Message without confirmation?
    By jimbo1mcm in forum Verizon LG G2
    Last Post: 04-24-2014, 01:43 AM
