1. CarrierPigeon's Avatar
    how do I do voice dial when there is no data connection? (using my Verizon Galaxy Note 3 with a T-Mobile prepaid SIM card with voice minutes only, no data at all)
    The Note 3 is paired with a bluetooth car speakerphone. S-Voice wouldn't work and just kept saying no data connection...
    thanks!
    04-24-2014 10:38 AM
  2. TheMacs's Avatar
    Do you not have a cell signal? If that's the case, you can't call.
    BTW, S-Voice is not the best. Try Google Now.
    04-24-2014 12:32 PM
  3. CarrierPigeon's Avatar
    Yes, there is cell signal... but since I'm using a T-Mobile prepaid SIM card with VOICE only, it doesn't have data.
    04-24-2014 01:28 PM
  4. TheMacs's Avatar
    Hmm, odd. Pretty sure you shouldn't need a data connection for Svoice to work.
    Have you rebooted? I'm still amazed how often this actually fixes things.
    Past that, it's time to start testing. Does voice dialing not work at all? (With no BT device connected.) Does it work with a different BT device connected? Just trying to maybe narrow down/isolate your issue.
    Also give Google Now a try, or another voice service. Again, to test.
    04-25-2014 12:32 PM
  5. CarrierPigeon's Avatar
    If I switch the default voice dialing to Google Now, it works fine. (Google Now can recognize my command even when there is no data connection) If I switch back to S-Voice, then I can't dial because S-Voice keeps telling me that it needs a data connection)
    04-25-2014 07:11 PM
  1. Galaxy S5: Is any replacement battery better than the original?
    By K83476552 in forum Samsung Galaxy S5
    Last Post: 11-21-2016, 07:08 PM
  2. Replies: 3
    Last Post: 09-05-2014, 05:09 PM
  3. DROID MAXX: Motorola Connect not working
    By motorcycle_monkey in forum Motorola Droid MAXX
    Last Post: 07-09-2014, 03:47 PM
  4. OnePlusOne: Root, now that Is the question...
    By vincentallen2 in forum OnePlus One
    Last Post: 05-18-2014, 09:50 AM
  5. really love the ok google voice control
    By M Max in forum Google Nexus 5
    Last Post: 04-26-2014, 05:31 PM
