1. Sefa Volon's Avatar
    When I enable Direct Dial widget at least for one contact, i lose ability to place calls using regular Phone app. I get "International number you are attempting to dial is not allowed from this line"
    as soon as I delete that widget, I can use Phone app. I dial local numbers.
    04-24-2014 05:05 PM
  2. lterry913's Avatar
    Is it a widget or a shortcut you are setting up...try setting up a short cut instead and maybe try a playstore contact widget and see if the same thing happens...Did you try a battery pull and a restart after installing widget...I have never had this issue with shortcut for contact or widget. I f it continues you will have to contact your carrier, I would think. They will probably suggest the dreaded factory data reset so you may as well try that if all else fails...good luck and maybe someone else will chime in.
    04-25-2014 08:29 AM
  3. Sefa Volon's Avatar
    thank you for your reply and wishing me luck. i've tried it all: restarting the phone, pulling the sim card out, contacting the carrier - nothing has helped. the phone is new - i just got it and set it up, it has barely anything on it. this is a widget that i'm tapping/holding and moving to my main screens.
    hopefully someone has a solution for this.
    thanks again,
    04-25-2014 08:53 AM
  4. lterry913's Avatar
    If you don't get a solution take it back before 14 days and insist on New phone not a refurb...I have not heard this happening...hopefully someone can help...but don't wait to long.
    04-26-2014 07:16 PM
  5. Golfdriver97's Avatar
    Perhaps a different launcher might be successful where the stock one fails. I would suggest Nova. You can find it in Play. I would download it, test the same thing, and if it works, you will have to set the phone up again. If not, uninstall Nova, and you have only lost out on the 10 minutes to test it.
    Sent from my HTC One_M8 using AC Forums mobile app
    04-26-2014 07:31 PM
  1. Replies: 8
    Last Post: 08-14-2015, 03:15 AM
  2. Verizon LG G2: KitKat 4.4.2 Bluetooth Voice Dialing Issue
    By jcpmojo in forum Android 4.4 KitKat
    Last Post: 11-20-2014, 05:39 PM
  3. Replies: 1
    Last Post: 04-30-2014, 08:34 PM
  4. how do I do voice dial when there is no data connection?
    By CarrierPigeon in forum Verizon Samsung Galaxy Note 3
    Last Post: 04-25-2014, 07:11 PM
  5. Why do launchers kill Sense widgets ?
    By Zorachus in forum HTC One M8
    Last Post: 04-24-2014, 01:34 PM
