1. sarkycow's Avatar
    Hi all,
    My husband, I and our friend are all on the same Verizon account. Up until maybe a month ago we all had seperate 2gb/month data plans but then we convinced (haha) our friend to get the note 3 too.
    It worked out a lot cheaper for us to switch to the shared 6gb plan. This works for us all because we are on wifi the large majority of the time.
    I know I can go to settings >> data usage or go into the my Verizon and see my data usage but is there a way for me to see the overall usage from everyone without logging into a PC? I tried on the my Verizon app but all it was showing was my own usage.
    We hope to do some traveling in the next couple of months (just within the US) so it would be handy to keep note if there is an easy way.
    Thanks!
    Sarks
    04-25-2014 02:03 AM
  2. daves221's Avatar
    My Verizon Mobile app does it.. Pre-loaded. Shows my family 's total data usage and breakdown by line. Widget shows data usage too (is pretty good actually and now updates without the use needing to ask for an update) . Also we receive text messages at set points of data consumption.
    Is your app out of date? Are you logged in to the correct account? Something doesn't sound like it's set up correctly as that app does exactly what you're looking for as I understand it.
    04-25-2014 04:35 AM
  3. sarkycow's Avatar
    Weird. Perhaps I have some setting wrong. It says I have version 10.0.615 and that it's up to date. The total data that it is showing though is only the data from my phone. When I checked my husband's data and my own the numbers don't match - it only matches my phones data.
    I am logged into the right account because I'm the account owner.
    I do have the alerts set to warn me when im reaching a 2gb limit - but that won't be much good if the other 2 phones have used over 4gb, ha.
    Not too worried about it - I was just hoping there would be some simple way to view all of us together.
    Tomorrow I guess I will fiddle around with it some and see if maybe I've done something so that it only shows my own usage.
    Cheers for the reply though :-)
    Sarks.
    04-25-2014 05:24 AM
  4. ansa82's Avatar
    Sarks.
    I'm using a widget called My Verizon shared data. It shows all lines on your account.
    sent from my Note 3
    04-25-2014 06:31 AM
  5. daves221's Avatar
    Sarks.. I'm on 10.0.650... Also in the upper right hand corner is the settings icon (gear) and the only thing in there which is to set the format for the widget. Are you able to add the data widget to your home screen? Does it refresh automatically (that was the most recent update)? Something is not right with what you are seeing.. Can you post a screen shot? (blurred)
    05-04-2014 07:31 PM
  6. daves221's Avatar
    Sarks - here's the screen I get when I enter the app from the homepage widget..(graphical summary of usage across all lines) If I click details, I go into the typical home screen for the app
    Sent from my SM-N900V using AC Forums mobile app
    Attached Thumbnails Easy way to view everyone's total data usage on my plan?-1399261163357.jpg
    05-04-2014 10:39 PM
  7. DLCPhototography's Avatar
    I've had the same question.
    It seems that all lines will only be shown to the "Primary" line phone, not the others, regardless of whether the others are the Account 'Owner.'
    My wife's phone is the Primary line, and I am the Account Owner. With the Widget, my wife's phone shows the usage for all the lines on the plan, while mine shows for my phoneline only.
    It shouldn't be this way, but as far as I can see, this is the way it works, and I don't see any way to change it.
    05-05-2014 07:00 AM
  8. dpham00's Avatar
    In that case just call Verizon and have your line made primary
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    05-05-2014 04:37 PM
  9. DLCPhototography's Avatar
    I figured out how to do it without calling Verizon.
    I just logged into the account on my desktop, and then chose the option to assign "Account Managers." I added my name and number, had to confirm via text, and the next time I used the Widget on my phone, it showed the data usage for all of my lines individually, along with the total. Perfect!
    dpham00 likes this.
    05-07-2014 06:15 AM
  10. dpham00's Avatar
    Good to know. For your situation that is fine, just beware that account managers have the same authority as the account owners, except that they cannot add or remove account managers, and maybe something else too.
    05-07-2014 09:43 AM
  11. sarkycow's Avatar
    Thanks for all the replies. Weird thing is that I am the account owner/primary (even confirmed that to myself by logging on from my PC to check).
    Oh well it is not a huge issue/problem. If I have a spare 5 minutes one day I might give Verizon a call and ask them.
    Cheers for all the help! :-)
    Sarks.
    05-07-2014 11:54 PM
  12. DLCPhototography's Avatar
    Sarks.
    Being the Account Owner, and having the Primary line, are not necessarily the same thing.
    Before investing time trying to get hold of somebody at Verizon, log into your account, and add yourself as one of the official Account Managers. If that doesn't do it, then it looks like a call to Verizon might be in order.
    05-08-2014 05:54 AM
  1. My LG Optimus L9 won't turn off
    By Ramirez9omaR in forum LG Optimus L
    Last Post: 05-04-2016, 03:18 AM
  2. Why no Verizon support on the OnePlusOne??
    By Snareman in forum OnePlus One
    Last Post: 01-20-2015, 07:49 AM
  3. Replies: 3
    Last Post: 04-26-2014, 10:19 AM
  4. Just got my Galaxy Note 10.1 ....what do you think of viewing angles and blacks?
    By stephanie85 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-25-2014, 01:31 AM
  5. How to check if touchpad is real?
    By ranajit saha in forum Samsung Galaxy S4
    Last Post: 04-25-2014, 01:23 AM
