1. Barry Test's Avatar
    Any suggestion for the above combo? I found reviews for a higher capacity battery, the same size as stock. It did not have good reviews.
    05-11-2014 10:51 PM
  2. alxarambula's Avatar
    Search for Zero Lemon on Amazon these are quality extended batteries. I had one for my galaxy s3 and it would last for days, didn't buy the one for the note 3 because the case has changed dramatically on the Note 3. Kinda looks like an otterbox case for the note3.
    05-12-2014 02:32 AM
  3. sgfdlt1819's Avatar
    Zerolemon is the way to go 72 hours out of a battery with moderate use.
    05-12-2014 08:07 AM
  1. Replies: 5
    Last Post: 07-12-2016, 03:01 PM
  2. Hancom word not open in note 10.1 2014
    By Nychotxxx in forum Samsung Galaxy Note 10.1
    Last Post: 05-25-2014, 10:38 PM
  3. Did I make the right choice.. Note 3
    By ChristopherH1 in forum Samsung Galaxy Note 3
    Last Post: 05-17-2014, 05:31 PM
  4. The Definitive "Improving-Your-Battery-Life" Settings Thread
    By PsychDoc in forum Samsung Galaxy S5
    Last Post: 05-12-2014, 01:48 PM
  5. Back Cover Creak Battery Cover Creaks
    By juststart in forum Samsung Galaxy S5
    Last Post: 05-11-2014, 05:40 PM
