1. steveL332's Avatar
    I did the OTA update to Kit Kat yesterday evening. The only issue I had was the connection to my Wi-Fi range extender. My phone said it was connected to it, but launching any app that required an internet connection failed. I could connect to my main router and it worked fine. This lasted about an hour, then the connection to the range extender worked fine and has since. I'm also not getting the typical unstable Wi-Fi messages anymore. It appears Verizon has fixed the Wi-Fi issue. So far everything seems to work fine.
    05-14-2014 03:10 AM
  2. rexxman's Avatar
    After update tried the camera. Nice shots, but couldn't find pics in the gallery. Noticed the default pic names were 2013....... WTF?
    Date/Time in Settings was now set to a date in April(?) of 2013. Checked box to set date to network date. Pic name problem solved.
    05-14-2014 08:28 AM
  3. steveL332's Avatar
    Yep, my wi-fi issues were fixed thankfully! I also noticed in the built in task manager when I had 4.3 there was only 2.1 GB of RAM that was available. Now after the 4.4 update, there is 2.7 GB available. So far I haven't experienced anything negative with the update.
    05-14-2014 06:18 PM
  1. Sign-in Request for the gallery after upgrade?
    By ShaggyKids in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-01-2017, 10:56 AM
  2. Not able to save backup to SD card after upgrade
    Last Post: 08-08-2014, 09:01 AM
  3. LED Notification Not Working After Kit Kat Upgrade
    By JarodL in forum Verizon Samsung Galaxy S4
    Last Post: 05-21-2014, 11:28 AM
  4. Kit Kat timing
    By acedl in forum Droid RAZR M
    Last Post: 05-19-2014, 04:02 PM
  5. Google Drive Download Does Not Work On Kit Kat Device
    By FSchmitthammer in forum Android 4.4 KitKat
    Last Post: 05-13-2014, 06:18 PM
