Upgrade to Kit Kat or not?
mzdrati
106
5
I know upgrading will mostly depend on how I use my Note 3.
My Note 3 is stock- not rooted (and I do not intend to root). I am not sure what the to believe about the SD card issues introduced by KK. I am on unlimited data, so I stream music from Google Music, but I store my photos & videos taken with the phone on my SD card, which I would like to continue to do. Jelly Bean 4.3 broke bluetooth compatibility with my hands free kit in my car, so I'm used to not being able to use that (it sucks to have to use a bluetooth headset when I drive). I do not know if Kit Kat has new / different bluetooth code that may restore compatibility but if it did, that would be reason enough to upgrade, for me. I use FoxFi, but I understand that it will still work after the upgrade, which is important to me. My battery life as it stands now in 4.3 is very good, as is the overall speed of the device. I drop calls once in awhile on this phone- so if the new KK code upgraded cellular signal strength somehow- that would also be a good reason to upgrade.
I've been holding out until I saw some posts that helped me make up my mind- but I have not seen any. Should I upgrade to Kit Kat- or will I regret it?
jenpossy
Active member
Mar 19, 2014
44
i have the note 3 too. i up graded and everything works the same no problems here. my sd works great you should have no problems.
zeuswsu
223
You can still store videos and pictures on your SD card with Kit Kat. The SD card issue stuff is overblown for most users. Seems like kit Kat might fix some of your issues too
Sent from my SM-N900V using Tapatalk
ansa82
1,837
44
48
Other than the battery symbol being white I've seen nothing else different. My sd card seems fine, battery is fantastic. I'm sure there must be some changes somewhere but I don't see it. All works fine
sent from my Note 3
shastrich2005
149
I was worried about the sd card issue as well. I was able to save all of my pics, videos and music to my sd card with no problem. So far no issues, knock on wood.
Sent from my Galaxy Note 3 using Tapatalk
mzdrati
106
5
I went ahead and upgraded last night. I found it to be slightly better, but more or less the same.
In case anyone reading this has the same bluetooth issues as I do- there was no change in my problems connecting to my hands free bluetooth in my car. It still connects, then moments later disconnects (and goes on that way indefinitely). Oh well.
Thanks for your replies!
anon154738
176
Overblown indeed. For most users this is no big deal! Is not broken. KitKat and SD cards ? what's fixed, what's broken and what's misunderstood http://www.androidcentral.com/kitkat-sdcard-changes
kirk781
