05-22-2014 11:44 AM
29 12
tools
  1. kami8586's Avatar
    I'm not sure if it's kitkats fault but something in Android system is killing my battery! Take a look.
    Attached Thumbnails Something is eating my battery!!-2014-05-16-16-41-40.jpg   Something is eating my battery!!-2014-05-16-16-41-30.jpg
    05-16-2014 03:45 PM
  2. kami8586's Avatar
    It didn't seem to drain like this as far as Android goes. I've had the update since Monday now
    Sent from my SM-N900V using Tapatalk
    05-16-2014 03:49 PM
  3. kami8586's Avatar
    I've had the phone off the charger for about 30,mins
    05-16-2014 03:50 PM
  4. z06mike's Avatar
    How much time was Google play services using?? How much screen time?
    05-16-2014 05:00 PM
  5. Nakrohtap's Avatar
    Is this a joke? 13 minutes off the charger and your at 98% and you want to know what's eating your battery? Am I missing something here?
    sforsyth01 and Kelly Kearns like this.
    05-16-2014 05:17 PM
  6. z06mike's Avatar
    LOL, I wasn't gonna go there, but you did!!! I was thinking the same thing, and it was 30 minutes off the charger.
    05-16-2014 05:21 PM
  7. Nakrohtap's Avatar
    Maybe there is a real problem. But, it's sure not illustrated in the screen captures. I know that my phone, before and after the update, sometimes has a quick surge in the first 15 minutes off the charger where it dips down like 5-7% before I even do anything. I just attribute it to synchronization and updating.
    05-16-2014 05:38 PM
  8. weatherlover1's Avatar
    Since getting KK I have noticed my battery life is much worse. Now that they have gone all apple and locked out seeing wakelock info I can't tell what the frick is causing it. I hate how android is locking all this stuff down very annoying so now if I want that info I have to root my phone and void my warranty. Not happy..
    tonyr6 likes this.
    05-16-2014 07:08 PM
  9. dss2000's Avatar
    I've noticed this for the past few weeks even before the KitKat update. Like yours seems like other than the screen, Android System, Google Play Services & Android OS are the biggest consumers. I first noticed it because It used to gain charge when charging in the car. With GPS on and Podcast playing through Bluetooth I would still be positive and charge at about +500mA. Now no longer, I'm doing -190mA using the same charger and same apps measured by Battery Monitor Widget.
    05-16-2014 08:23 PM
  10. itinj6's Avatar
    I get that Android System battery gobbler too... on occasion. It happened before I downloaded Kit Kat. Sometimes it steals more than 30% for me. It ate my battery alive before.
    05-16-2014 08:24 PM
  11. paradox60660's Avatar
    I used to use about 50% by the end of the day. Now by 4p I am less than 10% . Hopefully this will settle down after a few days.
    05-17-2014 11:00 AM
  12. joeyvaz's Avatar
    Anyone figure out why our batteries are draining so quickly? I've noticed the same thing for a few weeks now. No change since upgrading to KitKat.
    05-19-2014 05:33 PM
  13. kami8586's Avatar
    I actually just did a reset and it seemed to help a bit..I did lose my pictures though.
    05-19-2014 06:50 PM
  14. mchi5's Avatar
    People have said to do a factory reset. Unfortunately I have too many things that will be erased. So I went the other route. I got an extended battery instead. First the Anker 6400 mAh extended battery, now just ordered the Zerolemon extended battery
    Sent from my Samsung Galaxy Note 3 via Tapatalk
    05-19-2014 06:56 PM
  15. AdamHLG's Avatar
    Just to add.. I noticed the same thing and it's definitely kit Kat related. I've had no changes to the phone other than the update. It's very noticeable. 15 min off charger down to 94% with phone in my pocket! I'll do the reset. My battery was insanely great before the update.
    mchi5 likes this.
    05-19-2014 07:48 PM
  16. kami8586's Avatar
    Since my reset I've had my phone off the charger since 4:30 and I'm at 79%. Though while at work I do sit in my car and charge for roughly 15 mins which boost it up an extra 7-10%. I'm pretty happy.
    05-19-2014 09:25 PM
  17. AdamHLG's Avatar
    That's great except I have no idea where you live or what time zone you're in lol! Are you saying the reset worked?
    05-19-2014 10:11 PM
  18. Shannon Zabroski's Avatar
    I've been having same problem. Yesterday and day before it drained faster than my wife's GS4. I turned the 'location' off (was GPS before KK)...and that helps. But why the heck should I have to turn things off when I didn't have to before???
    Is the reset really working?
    05-19-2014 10:35 PM
  19. kami8586's Avatar
    It's 1:00 am now and I'm at 61%. Unplugged at 4:30 pm. Oh and I live in central Florida
    05-20-2014 12:01 AM
  20. kami8586's Avatar
    I also generally leave gps off since I don't it using up my data and it's a big drain I believe. I simply just turn it on as needed or before a trip somewhere. As well as all the palm view and air view.
    05-20-2014 12:02 AM
  21. Lee Hagan's Avatar
    That is exactly what is happening to my Note 3. . .
    Galaxy Note 3 was sent OTA update for kit kat 4.4.2 March 17, 8:10 am after that update the phone battery started dropping, the screen started freezing up and lagging, home button no longer was working, worst of all I can not send or receive text messages, phone call reception is poor and get more dropped calls in areas that use to be very solid reception. I did everything samsung and verizon told me to do, battery out and back in , sims card out and back in, empty cache, etc.... nothing worked! Very upset, can not communicate with my son via text messaging unless I make it a multimedia message and send via data, but still do not receive his texts back . . .the next day if I turn off the phone and turn it back on a few text messages will come streaming in . . but not all of them. My battery use to last a full day with heavy use and a day and a half with minimum use . . now it is only lasting 3-4 hours!?!?!?!?! I was told by Samsung that I can not remove the update but that they can "reflash the software" at one of their samsung experience shops (i.e. Best Buy). I called one of their experts and they told me that they will just re-install the update to make sure it was loaded correctly.??? That maybe it was interrupted during installation causing the problems. Nothing interrupted it . . and if this is true than how come the users that downloaded the updated via wired to pc are having the same problems?? Verizon offered a refurbished replacement. ., .I told them no way. I spent a lot of money and this phone is only a few months old. Does anyone know if the software update can be removed?
    RHChan84 likes this.
    05-20-2014 01:13 PM
  22. AdamHLG's Avatar
    I bit the bullet and just did a factory reset. After it settles down I'll post results.
    05-20-2014 01:23 PM
  23. RHChan84's Avatar
    Have you tried a factory reset? I see that you have tried everything VZW told you but there is no mention of a factory reset. Also reflash could help because when your downloading, parts of it might not of downloaded correctly. Think of it like this. Your sending nothing but 1 and 0 and each is a byte. The file is over 500mb so that's a lot of 1 and 0. The chances of some of them being messed up is very likely.
    Sent from my Droid RAZR MAXX (tapatalk)
    05-20-2014 01:24 PM
  24. dss2000's Avatar
    I have been able to improve my battery consumption, not sure if it is the root of the problem or not. One thing that seems to improve the battery for me was in the Settings / Wireless and networks / Mobile Networks / Network mode I changed it from Global to "LTE/CDMA".. I've also changed the Settings / Location / Mode to "GPS only". I've also turned off the Settings / Display / Smart screen. If you haven't tried those things might try to see if it improves things.
    05-20-2014 03:50 PM
  25. AdamHLG's Avatar
    Here is my follow up from the posts above. I can 1000% definitely report that factory resetting my phone fixed the battery issue. There is no doubt about it. No changes to phone prior to kit Kat update and after kit Kat update. Prior to update, with average use I would drop 10 percent battery in a few hours time. After Kitkat update it would drop 8 percent in 15 minutes and another 8-10 percent over next hour. So in same period of time, where I should have had 90% battery I had 70-75%. That is noticeable. After the factory reset I dropped to 95% battery after 2 hours of moderate use! So folks I strongly recommend a factory reset if you have issues.
    05-20-2014 09:41 PM
29 12
  1. What is this Icon, and how do i get rid of it?
    By Choice Rhymez in forum LG Optimus Series
    Last Post: 07-20-2014, 09:20 AM
  2. Is this possible?...
    By AndroidHTC2013 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 05-20-2014, 06:57 PM
  3. L is for....
    By LightaDroid in forum General News & Discussion
    Last Post: 05-19-2014, 12:56 PM
  4. Do I need 'My Verizon' app?
    By KeenAndroid3 in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-17-2014, 09:27 AM
  5. Is there a way to get my phone back to normal?
    By Lumos in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 05-16-2014, 03:43 PM
