1. kami8586's Avatar
    Hello everyone, lately I've been noticing that my Verizon network ratings have been higher than my wifi network. Mind that my wifi is the speeds of 90 mbs speeds? Is there a reason for this?
    Sent from my SM-N900V using Tapatalk
    05-17-2014 04:10 AM
  2. Nakrohtap's Avatar
    I don't see wifi speeds of 90 mBps in your screenshot. However, it is believed that Verizon either enabled band 4 on the Note 3 for the AWS spectrum for the national rollout on May 19th or possibly more cities have been turned on prior to the launch. I am thinking that the Note 3 just had band 4 enabled, judging by everyone's posts after the kitkat update.
    05-17-2014 07:49 AM
  3. Lefty Drummer's Avatar
    I was wondering the same thing the other day, that perhaps Verizon has turned on the new bandwidth early as my download speeds on 4G now are well over 50mbs just outside Baltimore. Never had that kind of speed over the network before.
    Sent from my Awesome Note 3 via the Android Central Forums App
    05-17-2014 07:56 AM
  4. dpham00's Avatar
    The grade is based on the speed at the specific test. Based on your screen shot, Verizon Mobile data is faster than your wifi, so it got a higher grade
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    05-17-2014 08:49 AM
  5. dpham00's Avatar
    05-17-2014 08:50 AM
  6. yarnsrj's Avatar
    My tests where done in 2 locations: 1st set of numbers in master bedroom furthest away from Verizon fios wifi router. 2nd set of numbers are taken in living room next to Verizon fios router.
    from "Ms Note 3" on Tapatalk
    05-17-2014 11:43 AM
  7. kami8586's Avatar
    See some of this makes sense but some of it doesn't. I figured since my wifi service through bright house would exceed more than 30 mbs or is it because I have my Xbox on iPad as well as wireless smart TV?
    05-17-2014 02:11 PM
  8. dpham00's Avatar
    Depends on WiFi signal,interference,network load.
    I have Twc 15mbps.at peak I have seen speed test well under 1mbps
    Sent from my ADR6425LVW using Tapatalk
    05-17-2014 05:36 PM
  1. My new race game: "High Laps"
    By Darie_P in forum Android Games
    Last Post: 02-21-2015, 09:22 PM
  2. Wifi Issues?
    By storino03 in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 05-18-2014, 04:29 PM
  3. Replies: 3
    Last Post: 05-17-2014, 01:16 PM
  4. WiFi international connections
    By Jwins3 in forum AT&T Galaxy S III
    Last Post: 05-17-2014, 10:09 AM
  5. New GS4 and New on Verizon
    By Sgooter in forum Verizon Samsung Galaxy S4
    Last Post: 05-16-2014, 11:17 PM
