Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Like Tree13Likes
    Default Reset your note 3 after kitkat.
    I reset mine last night and apps lol completely different. Phone seems much faster and less cluttered. I kept wondering why some apps didn't look the same on my wife's note 3. Now I know.
    Sent from my SM-N900V using AC Forums mobile app
    Rohan Mukkolath likes this.
  2. #2
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    Default Re: Reset your note 3 after kitkat.
    i have found that a factory reset after any major OS update is a good idea.
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Cool. Sometimes a simple cache clear does wonders, too.
  4. #4
    Quote Originally Posted by Golfdriver97 View Post
    How do you clear the cache?
  5. #5
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Quote Originally Posted by dss2000 View Post
    Rebooting into recovery from a powered down state.
    This should work for the Galaxy line: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    From an SOKP Nexus 5
    Spencerdl and dss2000 like this.
  6. #6
    anon154738's Avatar
    Posts
    Global Posts
    182 Global Posts
    Carrier
    AOKP/ Franco Kernal
    Does clearing cache wipe the phone like a factory reset?
  7. #7
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Quote Originally Posted by dhawk1202 View Post
    No.
    Sent from my HTC One_M8 using AC Forums mobile app
  8. #8
    honu85's Avatar
    Posts
    Global Posts
    34 Global Posts
    Will a cache clear remove anything from my phone? Or will I lose anything?
  9. #9
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Quote Originally Posted by honu85 View Post
    Nope. Just system data which is not user data.
  10. #10
    Ok quick question I'm thinking about reseting my note 3, will I lose all my pictures on and off my SD card? I'm not worried about the apps I can just re download them
    Sent from my SM-N900V using Tapatalk
  11. #11
    Quote Originally Posted by kami8586 View Post
    Take the sd card out before you reset then put back in after your done
  12. #12
    If you have tons of apps on your Note like I do, I wipe the cache every so often to keep thing running as smooth as possible. Also after Updates as well. I'm not a factory reset person with so much stuff on my phone to replace.
    from "Ms Note 3" on Tapatalk
  13. #13
    This. A factory reset seems like way too much work for me. The cache clear is relatively painless and improved my post kit kat better life
  14. #14
    pdub73's Avatar
    Posts
    Global Posts
    322 Global Posts
    Quote Originally Posted by jgraves1107 View Post
    What apps in particular look different?
    kami8586 likes this.
  15. #15
    The kitkat update cleared the cache automatically after the reboot.
  16. #16
    bdubbs033's Avatar
    Posts
    Global Posts
    7 Global Posts
    Why won't some videos play after the update?
  17. #17
    I tried this to get rid of the KitKat update pop up....didn't work. I'm afraid the only way to get rid of the annoying KitKat update pop up is to actually install this...this update. Does anyone know how to STOP the pop up?
  18. #18
    Hit install now Spencerdl. You will be just fine. V.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  19. #19
    Quote Originally Posted by spencerdl View Post
    http://img.tapatalk.com/d/14/05/19/da7ydega.jpg
    I read a message from Samsung that when you are notified of the update it will send you a notification every 30 minutes if you denie it
    and will continue until you download it!
    I don't think you have a choice!
    Mine downloaded yesterday and so far it seems just fine.
    A little more RAM, the battery seems to last a little longer.
    It added 3 new apps.
    So far it seems to be running great!
    Sent from my Samsung Galaxy Note 3
    "Size does matter!"
  20. #20
    Quote Originally Posted by Jalopiejoe View Post
    "Size does matter!"
    Thanks for the info. Looks like I have no other choice but to download ....KITKAT!!!
    Jalopiejoe likes this.
  21. #21
    pdub73's Avatar
    Posts
    Global Posts
    322 Global Posts
    All of the bugs in 4.3 are fixed.... if the only drawback is some 3rd party apps can't access the sd card I can live with that... probably safer that way anyway maybe that will keep my sd card from randomly corrupting
  22. #22
    how do u know this where it that imformation posted im still haveing issue wiyh mines...message lag...over all slow performance and battery drain
  23. #23
    The update caused me to lose my pics except for 7 of them. I am very mad over this. Didn't harm my music
    Posted from my awesome Note3
  24. #24
    I finally updated to KitKat last night (couldn't take the "pop up" anymore). It's NOT as disappointing as I thought it might be....I like it (smile). So far so GOOD, I've had none of the problems that I have read about (knocking on wood). I like the white battery icon in the notification bar and the other little enhancements that KitKat brings. It's to early to comment on the battery, but I will be keeping a close eye on my Note3 in the comig days as with any OS update.
    Lefty Drummer likes this.
  25. #25
    I agree and so far on my phone, I see no reason for a reset! It's running fine.
    "Size does matter!"
  1. Sound Cracking - KitKat Issues
    By acedl in forum Droid RAZR M
    Last Post: 07-01-2014, 01:23 AM
  2. battery since kitkat upgrade
    By Amir Hadanny in forum LG G2
    Last Post: 05-26-2014, 10:44 AM
  3. Replies: 3
    Last Post: 05-17-2014, 08:25 PM
  4. samsung galaxy note 3 help
    By mbabee in forum Android 4.4 KitKat
    Last Post: 05-17-2014, 10:00 AM
  5. How can I back up SMS, etc from my Note 3?
    By rockrchic923 in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-16-2014, 11:46 PM
