06-22-2014 04:11 PM
28 12
tools
  1. TimThompson05's Avatar
    I work in a LTE area and get pretty good coverage, but when I go home, my Note 3 on 4.4 gets maybe one bar of 3G or 1X if that. It's usually no signal what so ever. It has the circle with a cross through it. I used to get decent 3G or even LTE. I've already changed the Sim card a couple of times. I talked to Samsung and started getting somewhere then they said their system was down and to try again later. Any ideas to why this is happening. I know I'm not the only one having this problem.
    05-19-2014 01:10 PM
  2. srkmagnus's Avatar
    Welcome to Android Central!
    When you say used to get decent 3G or even LTE, do you mean with the Note 3 or with prior devices? Because a device can have an effect on coverage - good or bad - that may not be what you are used to.
    To start, I would suggest making sure the device is fully updated. Start there and see if there is any improvement.
    05-19-2014 05:07 PM
  3. dpham00's Avatar
    Contact Verizon for troubleshooting. From what you are saying, they would probably make sure that you have the latest update, make sure that you are in the coverage map, make you do a factory data reset, and then they should send you a replacement phone
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    05-19-2014 05:13 PM
  4. TimThompson05's Avatar
    Yes on the Note 3. All apps are updated. I can tell a slight difference from my previous phone but the signal on the Note has changed since then.
    05-19-2014 06:47 PM
  5. TimThompson05's Avatar
    My wife gets a good signal on her RAZR Maxx at home while I can be right beside her and have nothing. I just did a factory reset yesterday. And I bought the phone outright to avoid losing unlimited data and I don't have insurance. I will call troubleshooting soon.
    05-19-2014 06:50 PM
  6. dpham00's Avatar
    Hopefully you will get it sorted out. Sounds like a defective phone
    05-20-2014 09:09 AM
  7. brian181's Avatar
    Had the same problem on my note 3, around a month ago. Had periods of weak 3g and no-service. Data up/down speeds at, or below, 1mb (using speedtest). Spent a couple weeks with tech support: resetting, sim-replacing, waiting. they eventually sent me a replacement phone...problem solved. Would call tech support and to through their process. should eventually reach the point of them sending a replacement.
    05-20-2014 12:21 PM
  8. bertsirkin's Avatar
    Cell phone towers do go down periodically. You may find in a few days your signal gets better. But, you can always get a Network Extender like this:
    http://www.amazon.com/Verizon-Wirele...cUvbUpU3665325
    05-20-2014 12:22 PM
  9. TimThompson05's Avatar
    That's another thing. I don't have high speed Internet at home. We live in the sticks. Anyone know how long it would take to get a replacement from Samsung?
    05-20-2014 03:52 PM
  10. dpham00's Avatar
    I can get a replacement next day from Verizon free because I have TEC. If you don't have TEC, you can still get it next day but it might cost. I think free is 3-5 days
    05-20-2014 05:13 PM
  11. TimThompson05's Avatar
    Yeah. I bought my Note 3 outright without a contract to avoid losing unlimited. I didn't get insurance either. So yeah. Lol
    05-20-2014 05:46 PM
  12. dpham00's Avatar
    That's fine. It is still under warranty and Verizon will replace it.
    05-20-2014 05:55 PM
  13. TimThompson05's Avatar
    Seriously? But will they give me a new one or a refurbished one?
    05-20-2014 07:22 PM
  14. dpham00's Avatar
    If you are within the return period (14 days for verizon, 90 days for Costco) then you can get a new replacement within the return period. Note that regardless of return period, the contract is locked after 14 days
    After the return period, you would get a certified like new replacement
    TimThompson05 likes this.
    05-20-2014 11:52 PM
  15. TimThompson05's Avatar
    I've had my Note since mid October with no contact. I'll try and see if I can get a replacement because I don't see anything I can do to fix it myself. Thanks for the help.
    05-21-2014 01:38 AM
  16. TimThompson05's Avatar
    Oh and I bought it from Best Buy and not Verizon. Would that matter?
    05-21-2014 01:39 AM
  17. Kelly Kearns's Avatar
    Go to Verizon and get insurance on the phone before you do any troubleshooting. They can give you the insurance for a phone your bring to them.
    Oh just finished reading and saw you are still in Warranty, so that isn't an issue. I have had several refurb phones, SEVERAL, because of signal issues in my are, with AT&T. While they were working on the signal issue, they kept sending me to the Warranty Center to trade out the phone, to make sure it wasn't the phone. I was even doing some Beta testing for Facebook and having a problem with a lot of RAM being used by Facebook and got the Warranty Center to trade out that phone to make sure it wasn't a problem with my phone, causing that. Long story short, my old Note 2 was traded in a lot, but never had an issue with the refurbs, it was only traded in to rule out issues with the phone, when there were network and Facebook issues. Samsung goes through the refurbs and completely "makes them over" so you shouldn't have a problem at all with it being a refurb and you still have the same time left on your warranty.
    05-21-2014 01:57 AM
  18. DRILLINDK's Avatar
    I'm having the same problem. I've had my sim card replaced which didn't change anything. I contacted VW customer service today who started a ticket to evaluate the signal strength in my area (BOTH at home & work). I assuming its just the buildings I'm in. VW Rep stated they wouldn't offer a discount or free range extender since I'm on a corporate discounted plan. Little upset, since I've been a VW customer for over 13 years, have over a $275 bill every month. I'll wait to hear back on the network signal strength and go from there. I'm more concerned about cell phone signal strength than 4G as I log into my wifi networks at work and home. Coworker received a free range extender for her Sprint service and coworkers who have AT&T have great signal strength. Any suggestions?
    05-29-2014 09:49 PM
  19. HolyBuckeye's Avatar
    been having similar problems , but I've been posting in the thread that's just below this (4G not staying connected). One dude from Verizon was about to send me a replacement, and I said let me think about it (i didn't know if I just wanted to buy a new phone (M8). Now they're telling me it's normal for my signal to jump from 3G and 4G...
    yea, whatever guys
    05-29-2014 10:50 PM
  20. Baby_Doc's Avatar
    My phone has been working fine. I have had only a rare dropped call, although I was worried that I was only seeing 1 or 2 bars of signal strength at most while at home. Most of the time that was 3G. I took my phone to the Verizon corporate store where the reception was stronger and where I was now getting 3 bars of 4G. I went into settings, networks, and compared the signal reception on my phone with that of the demonstration Note 3 that was on display. There was almost no difference in the two phones. I felt reassured that there wasn't anything wrong with my phone. Now I seldom check the signal strength as long as I am not dropping calls.
    05-30-2014 02:27 PM
  21. TimThompson05's Avatar
    So Samsung is saying it was software related. It was factory reset and Odin flashed before it was sent in. Maybe it was antenna related software? Anyway, its on its way back to me. Hopefully it will work without any problems.
    Attached Thumbnails Crappy signal at home-screenshot_2014-06-02-18-21-18.jpg
    06-02-2014 05:32 PM
  22. TimThompson05's Avatar
    I'm switching to Sprint. See you guys on the other side.
    06-05-2014 08:53 AM
  23. HolyBuckeye's Avatar
    yea, i'm getting frusterated..
    I got my replacement phone, and i'm still dropping coverage..I'm just gonna send it back, and sell my Note 3 when the LG G3 comes out. I'm convinced it's a Note issue, never had this problem til I got this phone
    06-05-2014 04:42 PM
  24. HolyBuckeye's Avatar
    ugh, for the first time I just dropped to 1X coverage while I was at the gym
    Im getting tired of hearing from them, "well being inside will affect coverage....." I find it really hard to believe in 2014 when 4G is widespread, especially with VZN, that I will be dropping to 1X just because i'm inside a building, even in a movie theater I was keeping 4G coverage before
    06-12-2014 11:35 AM
  25. Jude526's Avatar
    Refurbished. All phones have a 1 yr. Mfg warranty. Only have a new replacement in the first 14 days. I have received refurbished before and look new as well as working fine. So don't worry.
    06-19-2014 02:15 AM
28 12
  1. Daily multiple freezes with S5 on AT&T
    By Bambii68 in forum Samsung Galaxy S5
    Last Post: 06-08-2014, 10:03 PM
  2. Signal Issues!!
    By terryh215 in forum Google Nexus 5
    Last Post: 05-24-2014, 04:21 PM
  3. s3 issues no signal and no service
    By Amanda30Ro in forum Samsung Galaxy S3
    Last Post: 05-21-2014, 03:51 PM
  4. S5 has poor signal strength .
    By jenpossy in forum Samsung Galaxy S5
    Last Post: 05-21-2014, 07:02 AM
  5. Kitkat at McDonalds.......Yikes!!
    By Jalopiejoe in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-18-2014, 03:08 PM
