Results 1 to 11 of 11
Like Tree1Likes
  • 2 Post By srkmagnus
  • 1 Post By TabGuy
    Default Data connection horrible since KitKat upgrade
    I did the OTA upgrade when it became available. Since then data connection has been horrible. In places where I got 3-4 LTE bars, I get "No Data Connection" or, sometimes, a 3G connection at best. This is very frustrating. I've change data selection to LTE/CDMA instead of Global without any change in connectivity. Sometimes a reboot will get me 4G in these places but that's a harsh workaround.
    Any ideas on how to fix this?
  2. #2
    Diabl0's Avatar
    Posts
    Carrier
    BAMF Forever 1.0.9
    Default Re: Data connection horrible since KitKat upgrade
    Quote Originally Posted by TabGuy View Post
    My phone is doing the exact same thing. It's very frustrating. I'm thinking I may have to do a factory reset, but I really don't want to. So far all KitKat has gotten me is worse signal and horrible battery life.
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,691 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    If you haven't already done so, consider a factory reset of the device. Often times it may be necessary to reset after a big update.
    If there still isn't a fix then know that toggling airplane mode will give you the same effect as a reboot, without the actual reboot. That still isn't an acceptable permanent solution, but should be used in the interim until a fix if released - assuming that it's a known issue with the update.
    dpham00 and Jalopiejoe like this.
    Quote Originally Posted by srkmagnus View Post
    I'm going to do a factory reset tonight. Doing the Helium backup now. I'll give it a few days and report back.
    srkmagnus likes this.
  5. #5
    I second the factory data reset. If that doesn't work, contact Verizon for a replacement
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
  6. #6
    srkmagnus's Avatar
    Posts
    Global Posts
    13,691 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Sounds good - keep us posted.
    Ok, I did the factory reset. Unfortunately, Helium will no longer back up to SD card so I had to back up to the internal memory. Unfortunately, I forgot to copy that folder to my PC before resetting. So, this was a real cold reset. Bummer.
    Signal seems to be better so far, but it's only been a day so the jury is out. However, I notice that battery life isn't as good. I got a new OEM battery today hoping that it was the battery, not the phone. We'll see.
  8. #8
    Weird, I was able to backup to sd on kk from Helium
  9. #9
    does yours sometimes don't let you text while you were on 4G or just wifi because everytime I try to text and I don't want to use my data I just want to use just the phone cause there's ways you can text without using data but mine won't let me ever since the new software it messed up my phone really bad
  10. #10
    ever since the new software on my phone its been acting so weird I can send a text message without both things being on the wifi and the data before the software I can use only the wifi to send text messages even without the wifi I could still send text messages and receive them perfectly fine but this new software doesn't allow me to do any of that so I want it off my phone how do I get it off my phone
  11. Thread Author  Thread Author    #11
    I don't text through Verizon, I have Google Voice and all of my texting is done through Voice. I have had no troubles texting.
  1. Tablet with PoE and Ethernet connection
    By habrown in forum General Android Device Chat
    Last Post: 03-03-2016, 05:24 AM
  2. Does Anyone Know How To Get Free Data From T-Mobile On The N7 2013?
    By Wildo6882 in forum Google Nexus 7 Tablet (2013)
    Last Post: 10-14-2014, 03:41 AM
  3. Replies: 6
    Last Post: 06-15-2014, 12:29 PM
  4. Replies: 7
    Last Post: 05-21-2014, 08:09 PM
  5. Hissing/buzzing sound when on "data" calls
    By swy81 in forum Samsung Galaxy Note 3
    Last Post: 05-19-2014, 01:13 PM
