Long Story Short :
My OTA update failed so I ended up using this method to update.
*** How To Update From JB 4.3 To KK 4.4.2 On Verizon RETAIL NOTE 3 *** - xda-developers
I had backed everything up using MyBackup Pro.
Now when I restore items they work until I reboot the phone then they disappear. On top of that, after disappearing, I get an error if I try to install from the PlayStore. Some of the data and settings I have in various apps are not easily recreated such as the Google Authenticator.
I have read that 4.4.2 saves the data into different folders than older versions so I am wondering if I can get tricky and copy the files over manually.
I'd do so, but am not sure where the new location of the stored files is.
Is this possible? Is there an easier way than manually moving files? Or is this a lost cause?
