Results 1 to 6 of 6
    brandonx1000's Avatar
    rule the air.
    Posts
    Global Posts
    1,312 Global Posts
    Default S4 Light Effect Lock Screen
    So I was at Verizon today and saw that the Note 3 on display used the same lock screen as the S4. It was the one with the beam of light. I cannot for the life of me figure out how to add this to my Note 3 without using a third party app from the store. I'll go back tomorrow to see if it was added to it as an app or if it's in the settings.
  2. #2
    jpr
    jpr is offline
    jpr's Avatar
    Posts
    Global Posts
    1,702 Global Posts
    Default Re: S4 Light Effect Lock Screen
    If you're taking about the unlock effect it is under lock screen settings if you have swipe unlock. I can't tell you if the Verizon version has the light effect but the T-Mobile model only has ripple and watercolor. But you can look for yourself and see if it's there since you have the phone. If you only have the same options as mine, there are a few apps in the app store that can give it to you. If you're not taking about the unlock effect then it's probably just a wallpaper.
  3. #3
    I don't think it does anymore with KitKat but in 4.3 when you set a live wallpaper on the lock screen it would default to the light beam unlock.
    Sent from my Nexus 7 using Tapatalk
    rule the air.
    Posts
    Global Posts
    1,312 Global Posts
    Yeah its the unlock effect and I only have watercolor and ripple
    Sent from my LG-V500 using Tapatalk
  5. #5
    If you can get the image you can set it as your lock screen from gallery...just download it and choose the pic, press menu, then set as...lock screen should be a choice...good luck.
    rule the air.
    Posts
    Global Posts
    1,312 Global Posts
    It's not an image, it's the lock screen animation when you drag your finger. Still no luck, the VZW model was 4.3 and I'm on 4.4.2. The live wallpaper trick doesn't help.
  1. Replies: 3
    Last Post: 06-23-2015, 08:59 AM
  2. Cracked Screen - Droid Maxx
    By jsm1985 in forum Motorola Droid MAXX
    Last Post: 06-04-2014, 05:02 AM
  3. Jabra Freeway and Galaxy S4
    By davedonofrio in forum Samsung Galaxy S4
    Last Post: 05-29-2014, 05:10 PM
  4. Replies: 0
    Last Post: 05-29-2014, 04:58 PM
  5. Can I View multiple lock screen widgets without rotating?
    By Terrorizer in forum Google Nexus 7 Tablet (2013)
    Last Post: 05-29-2014, 04:27 PM
