Results 1 to 8 of 8
    mgftp's Avatar
    Posts
    Global Posts
    265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Please help w/ "modified" secondhand Verizon Note3. Getting back to stock.
    I don't want this post to be too long but I need some help here, let me sum it up.
    I purchased a secondhand Note3 at what I thought was a good price ($300) off Ebay. I got it an it's been "modified", I see this SafeStrap thing at startup and a SuperSU App. I used the "RootChecker" app to see if it's rooted and it tells me no, although when I use Google to me it seems a device has to be rooted to have SafeStrap and the SuperSU app so I am already confused. I have owned 5-10 Android phones and love the platform, I have thought of rooting every one of them to get rid of bloat but get confused and scared whenever I look into it so although I consider myself technology friendly I know not much of this rooting, flashing, roms, kernel scene. So:
    - My goal is to get this phone back to stock setting, no SafeStrap or root of any kind if it's there, so the phone operates and is just as it would be if purchased new from Verizon. What is the easiest way to go about doing this?
    Thanks in advance.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,060 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Please help w/ "modified" secondhand Verizon Note3. Getting back to stock.
    Quote Originally Posted by mgftp View Post
    Thanks in advance.
    I am not very good with Verizon devices. However, if this were any other carrier, I would say simply reflash the stock ROM with Odin. You can find files on Sammible .com, and I can link to a guide that has steps to use Odin.
    Verizon's typically are trickier. They tend to encrypt bootloaders and such so that just using Odin isn't that simple. I would check out YouTube and enter 'Verizon Note 3 Odin' and see what results come up.
    http://forums.androidcentral.com/amb...-via-odin.html
  3. #3
    Lefty Drummer's Avatar
    Posts
    Global Posts
    370 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    .246 ICS
    Definitely check out YouTube, there are videos demonstrating how to return to stock via Odin. Pretty painless.
    Posted from my Awesome Note 3 via Android Central App
    mgftp's Avatar
    Posts
    Global Posts
    265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the replies guys.
    So if I can follow the steps to flash a stock rom with Odin I will be completely back to stock? It'll wipe out any root, unlocking, safestrap, or other modification that was made to the device from the previous owner?
  5. #5
    Posts
    Global Posts
    33,060 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    The only thing that is questionable is relock the bootloader.
    From a Carbon M8 and AC Forums app
    mgftp's Avatar
    Posts
    Global Posts
    265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Golfdriver97 View Post
    I am so sorry for my ignorance on this but would you mind explaining what that means exactly?
    I take it we are assuming my bootloader is unlocked and by flashing a stock rom with odin absolutely everything will revert back to normal but the bootloader will not relock? If I understand this correctly, how does this effect the device?
    Thanks, I really appreciate it.
  7. #7
    Posts
    Global Posts
    33,060 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    The bootloader is locked for security. As I recall, Samsung doesn't really lock bootloaders, but Verizon does.
  8. #8
    mike7728's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    with this phone u couldn't unlock the bootloader.
    Sent from my SM-N900V using Tapatalk
  1. Deleted stock OS and backup!!!
    By sLevVen in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 06-09-2014, 06:10 AM
  2. how to set phone to light up screen when i get a notification?
    By majdi suliman in forum Samsung Galaxy S4
    Last Post: 06-01-2014, 06:04 PM
  3. Need to remove sim card in a LG
    By Nephew Sam in forum General Help and How To
    Last Post: 06-01-2014, 04:30 PM
  4. Getting a second line... get the S5 or the Note 3?
    By fubaracing7374 in forum Samsung Galaxy S5
    Last Post: 06-01-2014, 10:44 AM
  5. Moving resident/factory installed apps to new device
    By pingwn33 in forum General News & Discussion
    Last Post: 06-01-2014, 10:09 AM
