Do you find it charges rather quickly? For example slower or faster than the included charging cable that came with the phone?
I'm also wondering from those who use this kind of device charger if you notice any discoloration on the backside of the devices you charged with that?
Notes from Deb's Note 3
The difference is about 1/16th of an inch. Because the wireless back is sloped at the edges like the original back it is actually easier to pick it up off of a flat surface. The wireless back is not flexible like the original back so you can't "peel" it off but must work a finger nail or credit card around the periphery to remove it.
It charges very fast but only if you use the Samsung charging pad. This is not a conspiracy however, the Samsung branded charging pad is the only one I have found that has a 2 amp output. All the other charging pads, stands, etc. that I have found in my searching have an output range of 700 to 1000 mAmps (0,7 to 1.0 amps). These will charge the Note 3 but only if it is off and you are willing to wait much longer in my experience.
I have not found any discoloration of the back (mine is black in color) nor does the phone or the charger pad ever get above room temperature to the touch.
