Results 1 to 4 of 4
    breadmanjp's Avatar
    Posts
    Global Posts
    44 Global Posts
    Default Alarm Issue
    Couldn't find any problems similar to mine so here goes...When I set the alarm on the Note 3 for a wake-up time, as soon as the alarm is to go off, the phone makes it go to "sleep" and the alarm never rings. I have tried turning off wi-fi, battery pulls, resets, etc..I'm not sure what is the cause but it acts as if I hit the 'snooze' button instead of setting off the alarm. Anybody else have this issue?
  2. #2
    Default Re: Alarm Issue
    Hmm no, clue but try installing an app with it's own alarm like nite clock by ned fox...super simple interface and get a lot of updates so pretty current...use the apps alarm instead of the android built in and see if the same thing happens...
    A few questions that could narrow things down
    Do you use an app killer?
    Any notification apps that you might need to exclude alarms on?
    Any apps at all that you have silenced that need to have alarm/clock excluded from the app list within the new app?
    Did you try turning the phone of and doing a battery pull or clearing the cache for the alarm app?
    Good luck and let us know what happens...check alarm and phone setting for notifications and check blocking mode in phone settings to see if anything can be changed there.
  3. #3
    Hmmm, I use timely now but when I used the stock app, I never had a problem. maybe try to clear app data and cache for the app
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
  4. #4
    Some apps have not been updated recently therefore do not work well with kit kat... I know the so app I suggested works on my phone and so does stock. So give one of those a try if clearing timely doesn't work.
  1. Fix LG G2 Signal Issues with Root and Rom?
    By one eye bear in forum Sprint LG G2
    Last Post: 10-13-2015, 02:23 AM
  2. T-Mobile LG G2 touch screen issues and repair
    By David Melgar1 in forum T-Mobile LG G2
    Last Post: 08-20-2014, 01:30 PM
  3. Maps/GPS issues since kit-kat
    By linebusy in forum Droid RAZR MAXX HD
    Last Post: 06-12-2014, 09:56 PM
  4. Note 3 USB Issue
    By Madbrood in forum Samsung Galaxy Note 3
    Last Post: 06-11-2014, 04:19 AM
  5. Strange Power issues
    By Northern.dj in forum Samsung Galaxy S5
    Last Post: 06-10-2014, 07:12 PM
