1. Batman8888's Avatar
    Just curious, how is the data reception for those of you on Kit Kat (particularly if you're on a VZN Note 3)?
    I have been having data issues in ALL areas around the city and suburbs within the last month or so where the most bars of data I'll get is usually 3 when I used to get 5 especially while outdoors. This is the sole reason that I am about to upgrade to 4.4 but just want to make sure that it will (or at least "should") fix the problem. If many of you already on 4.4 however are STILL having data issues it will at least then let me know that Kit Kat may not be the answer.
    Thanks.
    06-17-2014 12:31 PM
  2. dpham00's Avatar
    I don't have any data issues, but I didn't really see improvement in signal with KitKat.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    06-18-2014 08:43 AM
  3. anon8380037's Avatar
    Moved -
    06-18-2014 11:12 AM
  4. Batman8888's Avatar
    Thanks Dpham00 for the reply!
    06-18-2014 11:32 AM
  5. sarkycow's Avatar
    Thanks.
    My husband and I both have Note 3's running kit kat on Verizon. We have no problems with data at all. We didn't have problems whilst on JB either.
    Sarks.
    06-18-2014 12:34 PM
  6. Jalopiejoe's Avatar
    I am running KitKat on my Note 3 on the Verizon network and I have found no problem with data reception!
    Sent from my Samsung Galaxy Note 3
    "Size Does Matter!"
    06-18-2014 08:23 PM
  7. Batman8888's Avatar
    Thanks to all for your replies. I finally went ahead and upgraded to Kit Kat yesterday and I'm STILL finding that I only get around 3 bars for data when I used to get 5! Now I'm not sure at all what this may be caused by, but it's really pissing me off because it's slowing me down (sometimes I get no signal at all if in a bad area).
    Maybe Verizon has made some changes on their end and just won't admit it when I call them to troubleshoot.
    06-19-2014 08:39 AM
  8. conanheath's Avatar
    I don't know if I would blame the phone. I'm in Dallas and Verizon has went from good to mediocre 4G coverage over last couple of years. Motorola Razr and Samsung N3, didnt matter, Couldn't keep a 4G signal in town. That map with all the red is good advertising but I'm 3g more often than 4G around town. I remember reading an article where Verizon was having some issues keeping up in certain areas. I have a ATT N3 as my personal phone and I'm 4G lte 99% of the time. Now, if I'm out in the country, I'll have data on my Verizon long after I've lost data on Att. Speed or coverage, can't always have the best of both worlds.
    06-19-2014 12:16 PM
  9. dpham00's Avatar
    It could be Verizon repositioning the antennas. I noticed a substantial drop when they did this. Also, Verizon could have recently deployed xlte in your area which might cause you to decrease signal strength.
    06-19-2014 05:26 PM
  10. BBSeattle's Avatar
    No issues before or after kit Kat.
    I have had radio issues with phones before. Had the phones replaced and reception issues were gone.
    I would not be surprised if you had a hardware issue.
    06-19-2014 10:53 PM
  1. Anyone else having data connection issues?
    By oaklandm in forum HTC One M8
    Last Post: 06-22-2014, 07:50 AM
  2. Black screen on calls after kit kat
    Last Post: 06-17-2014, 08:00 PM
  3. mobile data not working.
    Last Post: 06-16-2014, 10:34 PM
  4. Is there a way to transferr data between sd cards?
    By android jack in forum General Help and How To
    Last Post: 06-16-2014, 06:45 PM
  5. Recovering data with broken screen
    Last Post: 06-16-2014, 06:43 PM
