4g drops to 3g indoors (Verizon)
JCH76
19
My signal seems to drop to 3g when I am indoors in certain places (restaurant, movie theater, etc) and sometimes even 1x, but not at my house. Anybody else have this issue with there Note 3 from Verizon? I have updated to KK too, anybody know how to resolve this issue??
kg4icg
424
8
If you are using the new aws frequencies that Verizon has, might explain why, 2100/1700 doesn't penetrate buildings like 700 mhz does.
kg4icg
424
8
It seems there are a lot of people having this issue on Verizon and it has to do with the last update.
Jude526
Trusted Member
Dec 13, 2010
3,936
109
Even before update it can happen. I was at a friend's on the 4th. Had 3g. As long as I have service it isn't a concern for me. Same at work. I never get bumped off or have dropped calls. Not a problem.
JCH76
19
My thing is it affects my data/Internet
mwb1957
110
For what it's worth my N3 and my last LG smartphone both would drop to 3g.
I learned to re-start the phone, and they would return to 4G most of the time.
Posted via Android Central App from my Rose Gold Samsung Galaxy Note 3
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
The phone should automatically switch from xlte to 700MHz.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3
Feb 8, 2013
16
Mine has been doing same thing. I'm tired of turning my phone on and off to get 4g. It's bad enuf the rates we pay just to have 4g...it would be nice if I could use it again!
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Sometimes turning airplane mode on and off can fix it. Not ideal though, but quicker than a restart.
ansa82
1,837
44
48
I'm wondering. . Is it best to have the phone set on "global" or cdma/lte? Does it affect anything?
sent from my Note 3
Mooncatt
Ambassador
Feb 23, 2011
10,758
321
83
sent from my Note 3
I keep mine on global because I travel for a living and I go through areas that are in Verizon's "extended network." You need global turned on to access those networks. It may show a roaming signal (last phone didn't but current one does), but as long as it reports extended network when pulling down the notification bar, you're not being charged roaming rates.
alxarambula
274
Yeah whenever I drop down to 3g I just hold down the power button and a phone options screen pops up and I turn airplane mode on and then off. It's a bit quicker then scrolling through the settings.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
You can also access it from the notification bar pull down. If it is not a default toggle, you can rearrange the toggle switches
conanheath
137
Verizon and their red map is pretty impressive. You can get service in the sticks but their LTE service sucks in all the big cities I visit around Texas. I never keep 4G throughout the day. 3g most of the time I check it. And it was the same on the Razr Max I had before N3. I also have an ATT N3 for personal use and never loose 4G lte in city. But, the trade off is I don't get great service in rural areas with Att. Pros and cons.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
In LA, i get 4glte everywhere i go outdoors. Most indoors too.
My Co worker has att and it has a weak signal at my building. Verizon is very strong. Really, you need to check your specific areas to see which carrier is best for you
Sent from my XT1028 using Tapatalk
JkMpB
5
I was in Verizon store and mentioned the 4G to 3G problem and they updated my SIM card and the problem is gone. I have 4G in the house
Trees
1,544
12
38
Did they replace the SIM card, or make some changes to the existing SIM card? Just trying to make sure I understand in the event I need to try this as a workaround. So far, I'm not encountering the 4G to 3G, or 4G to 1X problem - as reported here http://forums.androidcentral.com/verizon-samsung-galaxy-note-3/401572-4g-1x-no-service-verizon.html
