1. AdamHLG's Avatar
    Count me in as one of the folks that had rapidly draining battery issues post-Kit Kat. Based on a tip in another thread, I went into Google Settings, Select "Search and Now", Select "Voice", Select "'OK Google' Detection", and de-select the box that says "From Google Search app" which will also grey out the options for "from any screen" and "from lock screen".
    I am seeing HUGE battery performance from this tweak. And it makes sense as this was introduced in Kit Kat. If it works, and you want a better way to access Google Now voice search, download 'Home2 Shortcut' from the play store. Once downloaded, in Step 1, select "voice search"; leave Step 2 alone, In step 3, choose your launcher. Then press close. At the popup, select "Home 2 Shortcut" as the default HOME application. With this enables, one press of the Home button takes you to your home screen, and two quick presses of the Home button starts Google Now voice search.
    Your options may vary, but I see a huge difference.
    anon8380037 and B. Diddy like this.
    07-10-2014 05:35 PM
  2. B. Diddy's Avatar
    Good tip! You're right, unless you have the Moto X or one of the Droid Ultra line of phones (with the X8 architecture), you may end up burning through battery more quickly with any kind of "always listening" function. The X8 chip architecture has one low power core completely dedicated to always listening, which is why those phones don't have this problem.
    07-10-2014 05:51 PM
  3. sforsyth01's Avatar
    True BUT the always listening feature only listens when the screen is on. If the screen is off it should have no effect on battery life at all. Personally I use the voice detection and have no ill-effects on my battery.
    B. Diddy likes this.
    07-10-2014 06:18 PM
  4. B. Diddy's Avatar
    Ah yes, good point.
    07-10-2014 06:25 PM
  5. AdamHLG's Avatar
    It listens when the screen is off if u select that option. I tried it. I had selected 'from lock screen' under the settings described above. I was surprised it worked to be honest.
    07-10-2014 06:46 PM
  6. B. Diddy's Avatar
    Ok, clearly I don't know much about this, so it's good the learn this information ...
    sheaviousdroid likes this.
    07-10-2014 07:02 PM
  1. Battery Dying Real Quick
    By LocationDudeNYC in forum LG G Watch
    Last Post: 08-02-2014, 03:36 PM
  2. Replies: 3
    Last Post: 07-11-2014, 03:07 PM
  3. Battery drainer.
    By marshatherton in forum Sony Smartwatches
    Last Post: 07-10-2014, 03:18 PM
  4. Replies: 1
    Last Post: 07-10-2014, 12:33 PM
  5. S5 or S4 battery ??
    Last Post: 07-10-2014, 10:05 AM
