1. ansa82's Avatar
    My SD card stopped working. All my pics that were saved to it are no longer showing up in my gallery. I took it out and put it in a micro sd card reader but my computer isn't reading anything? My pics are all saved on the cloud but I'm irritated about the SD card. Do they just stop working? It is about 2 years old ๐Ÿ˜‚
    sent from my Note 3
    07-11-2014 04:09 PM
  2. mrmoe110's Avatar
    Happened to my wife a couple times when she had her S4 and happened to my twice with my Note 3. I think I formatted it in the phone settings but then had to format it thru the pc to get it back working.
    07-11-2014 04:12 PM
  3. ansa82's Avatar
    But even my computer isn't reading it? Should I try to reformat or just get a new one?
    sent from my Note 3
    07-11-2014 04:21 PM
  4. dpham00's Avatar
    I would try to reformat.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    07-11-2014 05:22 PM
  5. conanheath's Avatar
    They are a little more expensive but get a Samsung sd card. You shouldn't have any problems with it. I had a couple of older sandisk and a Polaroid cards and between S4 and N3 I had problems with all of them. Loosing data, unmount/remount problems and formatting never seemed to fix problem for very long. Got a Samsung and haven't had any issues since.
    07-11-2014 06:16 PM
  6. mrmoe110's Avatar
    sent from my Note 3
    The last time it happened to me I think I had to format it in the phone settings first to get it to show on the pc. Then I had to format it thru the pc again to get it completely formatted.
    07-12-2014 12:53 AM
  7. ansa82's Avatar
    Thanks everyone. Unfortunately neither phone nor pc is even recognizing it now ๐Ÿ˜•. I think I might be visiting my Verizon store and try a Verizon one this time. I did have a cheaper one from a micro computer center. Thanks for help!
    sent from my Note 3
    07-12-2014 07:16 AM
  8. mrmoe110's Avatar
    sent from my Note 3
    I don't know how much internal storage you have left but the sd cards at Verizon are way way overpriced. It's good the Note 3 has 32gb internal storage since it'll get you by for a while if you order one from Amazon or eBay. You'll save a good bit of change if you do that.
    07-12-2014 07:33 AM
  9. ansa82's Avatar
    Good idea, can you suggest a decent brand? I feel the last one I had was maybe not the best quality wise. It was very cheap from a discount place.
    sent from my Note 3
    07-12-2014 03:42 PM
  10. jettie1767's Avatar
    Happened to me about a month ago as well. I had to reformat the card and it is working again. Good thing I had auto backup to dropbox and google+ so I didn't lose any pics.
    07-12-2014 08:05 PM
  11. ansa82's Avatar
    Frustrating is that I pay for Verizon cloud and yet none of my videos will play. It says this file cannot play?
    sent from my Note 3
    07-13-2014 07:35 AM
  12. mrmoe110's Avatar
    sent from my Note 3
    SanDisk are OK. Samsung makes good ones too. Mine is a Toshiba, but like I said, I had to reformat it a couple times so another brand might be better.
    07-13-2014 09:32 AM
  13. paradox60660's Avatar
    You could call the NSA and ask them to send you copies of your pics.
    Sent from my SM-N900V using Tapatalk
    07-14-2014 01:40 PM
  14. ansa82's Avatar
    Ok Thanks!
    sent from my Note 3
    07-14-2014 03:28 PM
  15. Casey Cheung's Avatar
    I'm currently helping a friend with the same problem. She has a Sandisk 32GB microSD card that she used fine in her older Samsung S3 phone which contained thousands of pics. When she got her new Samsung Note 3 phone, she put in the same SD card from the S3 to the Note 3 phone. At first things worked fine for a few weeks, then suddenly one day all her old pictures were gone, except for a few dozen recent pictures taken. Weird.
    When I tried placing her SD card into the micro-SD card adapter and inserted into a laptop, the laptop could not find any of the older pictures in the D drive. I had not done any formatting/reformatting whatsoever for fear of erasing anything. I then went to CNET's site of Free software downloads and software reviews - CNET Download.com and installed a free Windows app called "Pandora Recovery". I specified doing a search in the D drive where the SD card is located, and after 30 minutes, the app had already found over 1,500 JPEG files. Because the search required longer time, I left yesterday before it finished. I will go back later today to see the outcome of the recovery. Hopefully the app will be able to recover the "lost" pictures.
    07-15-2014 01:04 PM
  16. ansa82's Avatar
    Thanks, I will give this a try! Last time I tried to put the defective sd card in the computer it wasn't even reading it in the drive at all! So odd!
    sent from my Note 3
    07-15-2014 02:01 PM
  17. Casey Cheung's Avatar
    Update here. The dang program worked! Pandora Recovery app worked! Took over an hour to recover over 3,000 picture and music files from the Sandisk 32GB memory card. I did the command called "Surface Scan" after specifying the "D" drive where the micro-SD card was located inside the laptop. After the process was completed, I then created a new folder on the Desktop (of the laptop), highlighted all the files within Pandora Recovery app that was found, then specified to copy all the recovered files to the new folder that was created on the Desktop. I was amazed. That Pandora Recovery app is good stuff! Free too!
    07-16-2014 09:35 AM
  18. ansa82's Avatar
    That is great to hear! I got a new sd card today but will still try to get the old one to recover. Thanks so much for info! I will try this!
    sent from my Note 3
    07-16-2014 01:18 PM
  19. Casey Cheung's Avatar
    You're welcome. Give it a try, worked for me! Here are 2 reviews I found on Pandora Recovery app:
    Pandora Recovery v2.2.1 Review (A Free Undelete Tool)
    Pandora Recovery Review & Rating | PCMag.com
    07-16-2014 02:42 PM
  1. DIVX playback issues /display problems
    By Simon Taylor 5 in forum Samsung Galaxy Tab 3
    Last Post: 07-26-2014, 10:42 AM
  2. Kit Kat Texting Issues
    By sparko24 in forum Droid RAZR MAXX HD
    Last Post: 07-13-2014, 02:27 PM
  3. Notification Issues
    By wezra in forum Samsung Gear Live
    Last Post: 07-12-2014, 09:06 AM
  4. Move apps to sd card???
    By AC Question in forum Sony Xperia M2
    Last Post: 07-11-2014, 02:37 PM
  5. Replies: 1
    Last Post: 07-11-2014, 10:48 AM
