1. ansa82's Avatar
    I had to get a new sd card. My old one was corrupted. Duh I can't find where in my camera settings to save pictures taken to the sd card?
    sent from my Note 3
    07-17-2014 07:23 AM
  2. lterry913's Avatar
    I'm not sure what you mean...but I usually just hook it up to computer and transfer from external sd to computer. Or you can use a file explorer and transfer/copy/save To internal storage on phone... then when you put in the new sd card you can transfer them back to external sd...but be careful...since KK some people say the phone will not show images and music file from external storage unless you use a third party app that is up to date and can find the info on your external sd...I would definitely store all info to computer and make sure you can view it before getting rid or moving anything on just the phone.
    Oh I forgot you could save them to a free cloud service and just view them from there if you don't want to hook to computer...just select the images and select what cloud service you want to share them with...drop box and picasa give like 5 gb free storage and more free if you recommend friends.
    07-17-2014 08:58 AM
  3. dpham00's Avatar
    It should be in your settings
    Sent from my Verizon Samsung Galaxy Note 3
    07-17-2014 10:38 AM
  4. ansa82's Avatar
    Yep I have them saved to cloud storage. My computer won't even recognize the old sd card and won't read it. I had to get a new one. Thank goodness for the cloud. I'm just bummed I lost videos. For some reason they won't play anymore even though there saved on the cloud
    sent from my Note 3
    07-18-2014 08:29 AM
  5. lterry913's Avatar
    There are some threads about renaming them so they play. I don't know much about that but the phone will only recognize file that end with a certain code. Maybe someone will chime in.
    07-18-2014 09:24 AM
  1. Replies: 2
    Last Post: 01-05-2015, 05:20 PM
  2. Verizon Moto X, black. In box with all accessories
    By MikeLip in forum Marketplace Archive
    Last Post: 08-01-2014, 09:47 PM
  3. How to move music files to SD card from internal memory?
    By Spokendisease in forum Ask a Question
    Last Post: 07-17-2014, 02:31 PM
  4. Trip to Canada help
    By Xanth269 in forum Motorola Droid MAXX
    Last Post: 07-17-2014, 01:39 PM
  5. Help!
    By Hugo Solomon in forum Samsung Galaxy S3
    Last Post: 07-17-2014, 08:23 AM
