Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Almeuit
  • 1 Post By lterry913
  • 1 Post By dpham00
    Casey Cheung's Avatar
    Posts
    Global Posts
    1,792 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I locked myself out and forgot PIN number - Help please
    I was screwing around with security settings, and inadvertently changed my PIN number to something different on my Note 3 phone. Now I'm locked out as I don't know what exactly is the changed PIN number. I can't access my phone now. Duh!! Anyone have a solution other than doing a hard reset?
    EDIT: Screen now says you have incorrectly typed your PIN 25 times, please wait 30 seconds to try agin. I'm not seeing any other alternatives to access my phone.
    Thanks!
    Casey
  2. #2
    VDub2174's Avatar
    Posts
    Global Posts
    5,775 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: I locked myself out and forgot PIN number - Help please
    Most I could say is to take it to your carrier. Maybe they can do something for you.
  3. #3
    Almeuit's Avatar
    Posts
    Global Posts
    23,131 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Do you have your Google account on your phone?
    Sent from my T-Mobile Note 3 using AC Forums.
  4. #4
    yarnsrj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hard reset bro. My step daughter did the same and couldn't remember the pattern. Call verizon but I'm pretty sure they're gonna tell you the same. Or keep trying the pin.
    from "Ms Note 3"
    Posts
    Global Posts
    1,792 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, I have a Google account, but that option is not showing up to ask me about it.
  6. #6
    Almeuit's Avatar
    Posts
    Global Posts
    23,131 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Casey Cheung View Post
    Login to Android device manager on a PC via your Google account.. From there you can setup a password which will overwrite the existing one.
    anon8380037 likes this.
  7. #7
    pcbtmr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Could you elaborate on this please? Is "Android device manager" a website for logging into, an application to download and from where? Is this something that TMO provides but not VZW?
  8. Thread Author  Thread Author    #8
    Posts
    Global Posts
    1,792 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks guys for your replies. I ended up doing a hard reset. Blah! Oh well, starting from almost scratch now.
  9. #9
    Almeuit's Avatar
    Posts
    Global Posts
    23,131 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by pcbtmr View Post
    It is actually an Android thing.. Not a carrier thing. Take a look at the link below. .
    http://forums.androidcentral.com/sho....php?p=3519413
  10. #10
    pcbtmr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is slick!
    I sent a Ring request to my old phone but nothing happened.
    Thanks for the info!
  11. #11
    lterry913's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know for sure but I think you have to allow android device manager to have control of your phone in phone settings under security>device managers...otherwise it will not have permission to access the phone.
    I could be mistaken. Someone may correct if I am wrong.
    Jalopiejoe likes this.
  12. #12
    dpham00's Avatar
    Posts
    Global Posts
    24,790 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lterry913 View Post
    You are correct.
    Sent from my Verizon Samsung Galaxy Note 3
  13. #13
    lterry913's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So android device manager will not let op into phone because it can not be made an administrator due to the fact he/she can't get into phone... Op will have to probably contact service provider to get them into phone so they can prove it is their phone.
  14. #14
    dpham00's Avatar
    Posts
    Global Posts
    24,790 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    That is correct, it would have to be set up before hand. I agree contacting the carrier is the best bet now, if adm isn't set up
    Sent from my LG G Pad 8.3
  1. HTC one m7 lock screen problem
    Last Post: 09-07-2014, 03:14 AM
  2. Lock Screen Notifications
    Last Post: 08-24-2014, 11:23 AM
  3. Replies: 50
    Last Post: 07-19-2014, 08:19 PM
  4. Is there a way to edit the display time of the lock screen?
    By wookiee2cu in forum Samsung Galaxy S5
    Last Post: 07-18-2014, 02:24 PM
  5. please
    Last Post: 07-18-2014, 11:10 AM
