1. Mooncatt's Avatar
    My fiance's Note 3 recently lost the LED flash function. It worked fine this morning, but tonight it didn't. She tried rebooting, but no luck. It also has a flashlight app that turns it on, but that also isn't working even though the indicator shows it should be on. She hasn't installed any new apps or made any changes on the phone, so I'm wondering if it's a hardware defect. Is there any test apps that can report wether or not the OS is truly trying to turn the light on that might point to software or hardware issue? Or any other suggestions before going the nuclear route of factory resetting or a warranty claim?
    08-08-2014 02:32 AM
  2. dpham00's Avatar
    Have you tried clearing cache in the bootloader? Also try clearing data in the camera app
    Sent from my Verizon Samsung Galaxy Note 3
    08-09-2014 07:06 AM
  3. JJJC1110's Avatar
    Also I found out that if it's below like 25 percent it will stop it from working
    08-10-2014 09:06 PM
  4. Mooncatt's Avatar
    Not sure what was going on, but it's working again. Didn't get to try clearing the system cache yet, so not sure if that would have worked. As for the low battery level, that likely wasn't it either. Not sure what level it was at at the time, but she said the flashlight app still works even as low as 3% on battery. I appreciate the help, even if it was all for nought this time.
    08-11-2014 09:29 PM
  5. dpham00's Avatar
    The stock camera app flash will stop working around 15% (maybe a little higher). But other apps should work
    Sent from my LG G Pad 8.3
    08-12-2014 11:39 AM
  1. update flash player?
    By steve1279 in forum Samsung Galaxy S5
    Last Post: 08-10-2014, 10:41 AM
  2. lost photos and videos
    Last Post: 08-08-2014, 02:27 AM
  3. lost mobile
    Last Post: 08-08-2014, 01:28 AM
  4. Can your phone still be bricked if you don't flash a Rom?
    By JellyJamStudios in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 08-07-2014, 11:06 PM
  5. Replies: 1
    Last Post: 08-07-2014, 05:37 AM
