1. christobal's Avatar
    Hello,
    I have had one small annoyance ever since I've gotten used to my Note 3. There are two phone icons available; "Phone" and "Contacts". Both open an app with the same tabs for Keypad, Recent, Favorites, and Contacts across the top. The Contacts icon launches the app with the Contacts tab open. The Phone app icon opens the app on the Keypad tab, which I rarely ever use to make a call as i obviously go through my Contacts to do that. Is there a way to make the Phone icon open the app with the Recent Calls tab open, or is there a way to create a Recent Calls icon so I don't have to go through the Keypad every time I want to view/return a recent calls?
    Thanks for your time.
    C
    08-23-2014 09:12 AM
  2. Jude526's Avatar
    No there isn't an app that I am aware of. I click on recent under calls if I am calling the number again. I also have a favorites screen with contacts I use frequently. You can get the widget icon under widgets and set up a screen x with numbers that you use. You have to set up individually. You can also add shortcuts to screen from the contact lizt. Select contact click on one you want click on home icon and then select shortcut to home screen
    08-29-2014 09:24 PM
  1. Callers can't hear me on the phone??
    Last Post: 08-24-2014, 01:53 AM
  2. Themes for stock keyboard
    By mhunter6378 in forum LG G3
    Last Post: 08-23-2014, 03:20 PM
  3. Replies: 0
    Last Post: 08-23-2014, 09:02 AM
  4. S3 help please
    By allysisa in forum Ask a Question
    Last Post: 08-23-2014, 07:16 AM
  5. Please help Samsung Galaxy ace 11 GTS7560M Battery issues
    Last Post: 08-23-2014, 06:38 AM
