Results 1 to 7 of 7
    Question Volume Question
    I'm looking for an app that can separate the gps and the mp3 player volume. Don't know if one even exists, but if it does I'd like to give it a try. Thanks for any help on this.
    Sent from my Atari 2600
  2. #2
    Default Re: Volume Question
    Quote Originally Posted by 757Dave View Post
    There are 6 different volumes you can control: Alarm, Media, Ringer, Alerts, System, and Voice call. I believe music is Media, and I think you are talking about Media for the GPS navigation that gives turn-by-turn directions. I use AudioManager app to view and change my volumes for each, and they have a nice widget to view them at a glance.
    Current: HTC One (M8), Pebble, Chromecast
    Retired Device (in order): Samsung Galaxy S4, Droid Razr Maxx, HTC Thunderbolt, HTC myTouch 4G, Blackberry's Bold, 8900 (Curve)
    Flames Wallpaper
    Jerry: "Love, Peace, and Chicken Grease!!!"
    Thanked by:
    Thanks! I'll check the app out right now. BTW, yes I'm talking about the turn by turn directions. I like to listen to my phone playlists over the car audio system and have the phone's gps giving directions at the same time. Even thought the music audio dips when the gps gives a direction, if I have the music set at a comfortable level I can barely hear the directions. I hope that this app will give the the ability to boost the gps volume without boosting the music volume as well. Again, thanks for the info.
    Thanks, but didn't work. Don't know if what I am looking for is possible. I think they both use the same volume control (media volume) and I can't separate them. So guess I'm stuck.
  5. #5
    I did not say this app would work... I just wanted to explain that there are only 6 volume controls and I thought the Media volume was what was used by both the GPS turn-by-turn and the Music app.
    Flames Wallpaper
    Thanks again, though. I'm a little slow sometimes, but I do eventually get there. One quick question - I can see the list for the six volume controls and get most of them, but what does the system volume do?
  7. #7
    Some say camera shutter, battery warning and other system sounds... all I know for sure is that when I put my device in Silent or Vibrate it turns the system volume down to zero... I like using Tasker to set some volume levels or going to vibrate only while I'm at work. Most of the time I just worry about the other 5 volumes.
    Flames Wallpaper
  1. volume question
    By sleepyrey in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 01-21-2012, 02:01 PM
  2. Media Player Volume Question
    By Funky Cricket in forum Sprint Epic 4G
    Last Post: 08-22-2011, 02:23 PM
  3. ringer volume question. how to make it twice as loud
    By matt512 in forum Motorola Droid X
    Last Post: 09-22-2010, 09:06 AM
  4. Low volume question for N1 owners
    By scaots in forum Google / HTC Nexus One
    Last Post: 09-05-2010, 06:17 PM
  5. volume question since 2.2
    By pastorsteve in forum Motorola Droid
    Last Post: 08-23-2010, 10:14 AM
B
