So I was having an issue getting my S4 to connect to my computer. (windows 7)
I manually downloaded the drivers from Samsung. That didn't work.
I downloaded Kies. That didn't work.
I changed USB cables to the stock white Samsung cable it came with. That finally worked.
I was using an old blackberry cord that worked fine on my Thunderbolt so I figured there was no way this could be the issue. Well it turns out that it does make a difference. With the old cord it would only charge & the computer would do nothing & the phone would only say charging & not give the usb option in the drop down menu.
I couldn't find anywhere on the internet that came up with this solution so thought I would post it.
ps. Anyone know why the cord would make a difference?
