03-03-2015 01:26 PM
36 12
tools
  1. brad419's Avatar
    I get no sound when I get a message. Set on whistle and vibrate, get neither one. Help. GS4
    06-18-2013 08:59 AM
  2. Golfdriver97's Avatar
    Try Settings>Sound>Volume. Your notification volume may be turned all the way down.
    06-18-2013 09:55 AM
  3. Jefstead's Avatar
    I have a similar problem. Text/MMS are received and vibration works, but the selected tone does not play even with all volumes set to max.
    06-20-2013 05:51 PM
  4. Zooks64's Avatar
    A friend with the Sprint version had this same issue. He had to do a factory reset to get his notification sounds to work again.
    miranda fisher likes this.
    06-22-2013 06:58 AM
  5. Bionic Bobsled's Avatar
    Did you ever find a solution for this? I'm having the same problem with my 1 week old S4.
    07-30-2013 10:34 AM
  6. Alex Myers1's Avatar
    GS3. Same problem. Volume at full, notification sound and vibration selected, nothing happens when receiving a text. Am I missing something?
    09-04-2013 04:37 AM
  7. jawiler's Avatar
    Do you have Timeriffic installed? It kills the sound, I had to uninstall it and now I have sound again.
    gdivanach likes this.
    09-04-2013 06:19 AM
  8. fatboy97's Avatar
    Recommend an app called AudioManager... there is a free version on the app store.... it will show you the SIX different volume controls on the S4 (Alarm, Media, Ringer, Alert, System, and Voice call).
    09-04-2013 02:04 PM
  9. larua66's Avatar
    My husband has the GS3, received an update to the operating system a couple weeks ago to Android 4.1.2. He noticed a couple days ago that he gets no notification at all when he receives a message (no numbers on the messages icon, no sound, no vibration). Could the update to the OS cause this?
    09-05-2013 08:56 PM
  10. trucksmoveamerica#AC's Avatar
    When is android going to fix this problem. This has been a issue since droid x. There are people reporting same thing with the new droid max. Sad thing is it don't effect every phone so that is probably why it's still a issue
    Sent from my SCH-I545 using Tapatalk 4
    09-05-2013 10:30 PM
  11. maurice0110's Avatar
    Having same problem with my Galaxy Note 2 .Any solution or help ????
    09-09-2013 10:26 PM
  12. Matt Mitchell1's Avatar
    I had to go into the stock messaging app and choose the notification sound in there. It was set at Default Notification but no Notification sound was actually set. Once I chose one from the list and hit OK I was good to go. It shouldn't be this complicated.....
    09-13-2013 09:56 AM
  13. larua66's Avatar
    After trying numerous things, my husband went to the AT&T store. Turns out, an update to AT&T Messenger had taken over. The AT&T guy went in and disabled the AT&T Messenger app and now all works as before!
    09-13-2013 09:12 PM
  14. janasaurus's Avatar
    I had this problem. on my galaxys2.. go into messages and then into the message menu, go right to the bottom and click rington. and then put in a tone. worked for me, hope it works for you
    10-20-2013 10:42 AM
  15. Scifidad's Avatar
    I too lost my notification and sounds on Messaging,(November 22, 2013, Bell Network, Canada)
    S3 messaging notification and sounds worked fine up to 24 hours ago, I did nothing but used my apps,
    At mid day i sent a note to message to a family member, when they did not respond I looked at the phone and to my surprise they had replied hours early but I did not receive the notification.
    I have since done each and every noted fix on this forum with no favorable outcome. I have also reloaded the current version of firmware this morning with no change to the loss of notification and sound on Messaging. What is next full factory RESET? Please say NO!
    Surely SAMSUNG has a fix for this? Tell me again why I switched from BB?
    11-23-2013 09:47 AM
  16. fatboy97's Avatar
    Your FIRST POST... and you in the Wrong Forum... AND BAITING people with "Tell me again why I switched from BB?"... ok, maybe you should go back to BB.
    You tried everything... and messaging notification is the ONLY thing that is not working? You can get other notification sounds, music... if so it's of course not your speakers. I guess if you can not trouble shoot your problem, then you should be doing a factory reset.
    11-23-2013 01:09 PM
  17. msndrstood's Avatar
    He's having a problem that others have had, with different phones, so he was asking for help. How is he in the wrong forum? So it's an S4 forum, others with different models are asking too.
    Lighten up about the BB, he's new, give him a break on forum protocols. Geesh.
    Sent via The Big, Bad, Beautiful Note 3
    11-23-2013 02:25 PM
  18. fatboy97's Avatar
    I'm guessing you did not read the post... here, let me help.
    Not only Bell network device, but also an S3.
    I was also trying to give some advice about trouble shooting, but of course it's a little hard to say what their issue is since they said they tried everything... what is everything... what did they find. Factory reset is another good way of trouble shooting.
    11-23-2013 03:43 PM
  19. msndrstood's Avatar
    Aaaand, others from ATT, and Sprint, with S2's, Note 2's, other S3' s also had this problem. So I don't fault the guy for posting in a forum where others with similar phones are having the same problem on other networks.
    My point is, kindness to a new member goes a long way.
    Aquila likes this.
    11-23-2013 04:07 PM
  20. Scifidad's Avatar
    Brutal Group on the forum but no worries! I wandered into the local BELL Store this afternoon and after a few moments the Manager noticed that my phone had loaded in Google Hangout was not fully installed and took over the SMS notifications section of my phone, Once fully activated my SMS notification both icons and sounds came alive though I am now stuck with Google Hangout as my primary SMS App. For those who have had a similar issue, this is something to look into where Hangout or another SMS that may be loaded on your device.
    For this who were not appreciative of my first post, if you get past your ego and attitude you may find a solution in someone else's post!
    Everyone have a safe and fund holiday season!
    11-23-2013 05:37 PM
  21. fatboy97's Avatar
    I'm glad you could find a fix without having to do a factory reset. Egos aside, you really need to know what apps, or patches are loaded onto your own device in order to figure out what might be causing your own problems. I'm sure you realize by now you would have never been able to troubleshoot this issue with the limited information you provided... and apparently some store reps have actually seen this issue. Personally, I had disabled Hangouts on my device when it first wanted to download on my device.
    And I hope someone will "fund" my holiday season soon!!!
    11-24-2013 09:45 AM
  22. raymoto's Avatar
    Hangouts has introduced yet another bunch of settings, which seem to supersede those of SMS.
    Open up Hangouts and its menu, then select your chosen notification sound.
    Worked for me.
    03-02-2014 02:15 PM
  23. humannoy's Avatar
    My S4 has the same problem but I uninstalled Hangouts and the messaging sounds worked perfectly.
    03-09-2014 12:56 AM
  24. Sandra Byington's Avatar
    Same problem here. Please let me know if you found a solution
    03-11-2014 12:21 PM
  25. Sandra Byington's Avatar
    I uninstalled Google Hangout and the sound now works again when I receive text messages.
    03-11-2014 01:08 PM
36 12
  1. Replies: 11
    Last Post: 04-07-2013, 03:11 PM
  2. How to extend or repeat a sms or text message notification sound
    By Mel Vine in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-21-2013, 07:35 AM
  3. Message Notification Sound cant silence?
    By Rammsteinfan in forum T-Mobile Galaxy S Blaze 4G
    Last Post: 07-24-2012, 04:12 PM
  4. Text Message Notification Sound?
    By yenrab26 in forum AT&T Galaxy S II
    Last Post: 01-11-2012, 03:47 PM
  5. Is there a notification sound for missed messages?
    By nneptune in forum Verizon Droid Incredible
    Last Post: 07-23-2010, 01:47 PM
